Event and Project browsers
COW Forums : Apple Final Cut Pro X Debates
Robb Albrecht
on Sep 7, 2011 at 6:11:11 pm
Will every event and sequence I make with iMovieX will show up in the browsers?
I do a ton of versions and alternate sequences of spots and 30 minute shows for a bunch of different clients and it seems like the browsers will get cluttered up really quick. I don't see a way around this, is there one?
Robb
alban egger
Re: Event and Project browsers
on Sep 7, 2011 at 6:31:56 pm
First the in-FCPX solutions:
Events cannot be placed into folders, so they are all open when the disk is mounted
Projects can be put into folders, so that helps
outside FCPX
there is an app (i think it´s called eventmanagerX), I don´t use it, because I use the next method, but I heard it works good
The easy way is to create directories where you park your events and projects. I always have a structure "year/client/project/" in here I create "FCPEventsParked" and "FCPProjectsparked". Once you drag your Event and Project out of the "root/Final Cut Events" and "root/Final Cut Projects" they are not visible in FCPX anymore. Takes a second.
Actually...I might take a look at this eventmanager app myself now, haha.
Noah Kadner
on Sep 7, 2011 at 6:32:43 pm
There is if you have $4.99 to spare:
http://assistedediting.intelligentassistance.com/EventManagerX/
Noah
40% discount for Creative Cow users with code ccow2011 at Call Box Training.
Featuring the Panasonic GH2 and GoPro HD Hero.
Steve Connor
on Sep 7, 2011 at 6:51:48 pm
I can thoroughly recommend EventManagerX.
"My Name is Steve and I'm an FCPX user"
Mark Dobson
on Sep 8, 2011 at 4:43:34 am
I too would really recommend EventManagerX.
I've got EventManagerX on my dock next to FCP X and it's really easy to use.
As time passes having control over your events becomes more essential. FCP X works better with less clutter. That's with both events and projects.
Robb Albrecht
on Sep 9, 2011 at 6:39:18 pm
Thanks for the tips, guys. I'll give EventManager a look.
Robb
