Broadcast safe filter
COW Forums : Apple Final Cut Pro X Debates
Oliver Peters
on Aug 16, 2011 at 2:04:08 am
Is this working for anyone? I can crank color ranges to both extremes of the waveform and apply the broadcast safe filter. No effect. I'm working with 1080p footage. Of course it only says NTSC and PAL, so does it work in SD but not HD?
- Oliver
Oliver Peters
Re: Broadcast safe filter
on Aug 16, 2011 at 2:09:27 am
No effect in an SD project either.
- Oliver
Orlando, FL
http://www.oliverpeters.com
T. Payton
on Aug 16, 2011 at 2:38:30 am
As odd as it sounds, FCP X renders the effects stack from top to bottom. So the broadcast safe filter is rendered BEFORE the color correction. Because FCP X renders in float, all the information is still there which makes it look like the broadcast safe filter has no effect. Therefore you don't want to apply this to individual clips.
You've got two solutions:
1. Finish your project and then group it in a compound clip, and then apply the broadcast safe filter to the compound clip. Only when you are viewing the timeline that contains the compound clip (not the compound clip timeline) will you see the filter.
This is actually exactly how I worked in FCP 7. Finish and edit, and then I would place it in a new sequence, put in my titles, countdown, etc. and apply the broadcast safe filter.
2. Add broadcast safe filter to an adjustment text layer. Make sure it is on top of your other layers. You might take this further and do a tiny amount of work in motion and create a broadcast safe text filter. Here is a link to the adjustment layer:
http://www.fcp.co/forum/4-final-cut-pro-x-fcpx/334-super-useful-use-clean-t...
3. Color correct manually to a broadcast safe: This is what I try to do and is probably the best practice. Can be used in conjunction with #2 and #1 above.
I think you'll actually find that the FCPX way of doing this is pretty smart, especially with adjustment layers.
- T.
T. Payton
OneCreative, Albuquerque
Rafael Amador
on Aug 16, 2011 at 11:07:08 am
[Timothy Payton] "As odd as it sounds, FCP X renders the effects stack from top to bottom. So the broadcast safe filter is rendered BEFORE the color correction."
That sounds odd?
That's the same pipe-line than in FCP.
What IMO makes no in FCPX pipe-line, is setting the "Color Correction" after the effects.
Will you CC your footage after you have applied your wind-blur?
rafael
http://www.nagavideo.com
Jerry Hofmann
on Aug 16, 2011 at 12:29:52 pm
Wait Tim... I have a clip which I've not corrected in any way. It has super black (about 5 IRE lower than 0) and whites are around 110. I add the filter. Nada happens... If I make the clip a compound clip, it works just fine on it. This isn't the way it's intended to be don't think...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Oliver Peters
on Aug 16, 2011 at 11:03:34 pm
Yep. Adjustment layer works. I also feel that this is ill-designed or a bug. Thanks.
- Oliver
Orlando, FL
Rafael Amador
on Aug 17, 2011 at 5:14:22 pm
[Oliver Peters] " Adjustment layer works"
Apple make things easy.
rafael
Jerry Hofmann
on Aug 16, 2011 at 2:33:06 am
NOt working here either... probably a reportable bug.
Jerry
Jerry Hofmann
on Aug 16, 2011 at 12:26:51 pm
OH brother. Still feels like a bug... sure enough, if I turn a single clip into a compound clip, then the safe filter affects the clip. I don't understand why it doesn't affect the clip if it's not a compound clip. It should according to the manual... it says nothing about the findings in that thread.
Jerry
kely bui
on Oct 3, 2013 at 9:33:43 am
Normally I do not read article on topics, however I wish to say that this write-up very forced me to try and do so! Your writing taste has been amazed me. Thanks, quite nice post.
http://www.kizi2.com | http://www.hopy.org.in
Alexandan robert
on Feb 16, 2014 at 4:42:47 am
Very good article and very rewarding good work! Thanks
http://www.friv2x.org | http://www.friv3x.org
Alexandan mariom
on Apr 23, 2014 at 8:50:22 am
Very good article and very rewarding good work! Good post
http://www.friv2x.org | http://www.kizi2games.co.uk
