FCPX Slow Rendering (Project Export)
COW Forums : Apple Final Cut Pro X Debates
Greg Summers
on Aug 10, 2011 at 2:26:16 pm
Why on earth would a 10 minute project with 7 or so titles and a couple of compound clips take over 4 hours to export/render? Gotta be something I am doing wrong.
Jeremy Garchow
Re: FCPX Slow Rendering (Project Export)
on Aug 10, 2011 at 5:04:12 pm
What is your codec of the clips and is the timeline rendered before exporting?
Greg Summers
on Aug 10, 2011 at 5:40:58 pm
I use a number of cameras but in this case the entire podcast was shot with the HDV camera.....1080i 1440x1080 29.97. Most of the other shows use a combination of the iPhone 4 720P footage and the HDV camera. Just don't remember it taking so long to render with the mixed footage. The timeline is already rendered.
John Pale
on Aug 10, 2011 at 7:29:50 pm
What codec are you exporting to?
Also, what method are you using to export? Some methods will ignore your render files (from the timeline directly to Compressor) and re-render directly to your target codec, which can take much longer, but result in a cleaner encode.
