fcp x doesn't show g-raid as option
COW Forums : Apple Final Cut Pro X Debates
jonathan butler
on Jul 19, 2011 at 7:51:27 pm
when import from camera i have no option to store on g-raid. only let me stores on hard drive and of course i have no room for the amount of information uploading.
how to make scratch disk g-raid?
John Pale
Re: fcp x doesn't show g-raid as option
on Jul 19, 2011 at 7:56:37 pm
Support for the letter G was dropped in this version. The programmers couldn't be expected to support all 26 letters of the alphabet in V.1 of this software.
No.. Seriously ..... Your drive must be formatted HFS+ aka MacOS Extended.
It can't be NTFS or FAT 32.
jonathan butler
on Jul 19, 2011 at 8:01:41 pm
i don't know what mine is formatted at? how find out and how change? will this affect other files on the g-raid if re-format? it worked fine for previous versions of fcp...is this a due to new fcp x programming?
TImothy Auld
on Jul 19, 2011 at 8:13:29 pm
I think that as a default G-DRIVE's are formatted in this way. No?
bigpine
John Pale
on Jul 19, 2011 at 8:32:09 pm
Click on the g raid in the Finder and then press command-I (get info)
It will tell you how its formatted in the Get Info window.
If it's not HFS+ (Mac OS Extended), you would need to re format it. Unfortunately, this means copying all the data to another drive and erasing it. You do that using Disk Utility located in your Utilities Folder.
Unlike previous versions of FCP, your drive must be MAC Formatted to use it with FCPX.
G-Raids usually come Mac Formatted, however, someone could have reformatted it before it got in your hands.
