Digital hits, usually green blocks, on renders
COW Forums : Apple Final Cut Pro X Debates
Bob Woodhead
on Aug 5, 2019 at 11:01:28 pm
Infrequently I'll find digital hits in the shape of small rectangles, usually green, on rendered footage. They'll be in a section of timeline, always play back in the same spot, can pause on them, export out, and have gone away when I clear cached renders. I would assume bad sectors on my external SSD, but not sure of a method to analyze the drive. SMART status doesn't work on external USB, and Disk Utility doesn't help.
Suggestions?
Dom Silverio
Re: Digital hits, usually green blocks, on renders
on Aug 7, 2019 at 3:23:41 pm
What kind of Mac and GPU are you using?
Bob Woodhead
on Aug 7, 2019 at 3:30:00 pm
Late 2013 Mac Pro D700s
Dom Silverio
on Aug 7, 2019 at 3:49:16 pm
Unfortunately, this is a design flaw on that Mac. During heavy CPU and GPU usage, the computer is unable to dissipate heat fast enough thus can cause random corruption. I highly recommend keeping renders in short bursts to prevent heat build-up.
Bob Woodhead
on Aug 7, 2019 at 4:29:10 pm
Wow, I was sure it’d be a drive problem! I’ve got a utility that overrides the internal fan speed control, I wonder if there’s a utility to change the thresholds (the one I’ve got is just manual constant speeds).
Bob Zelin
on Aug 7, 2019 at 5:27:40 pm
issue known for years -
https://macperformanceguide.com/blog/2015/20151212_1206-MacPro2013-BadVideo...
https://forums.adobe.com/thread/1686261
bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
Bob Woodhead
on Aug 10, 2019 at 2:53:43 pm
Never ran across those articles, so thanks Bob.
For anyone reading this, there is a utility called Macs Fan Control, and there is an option to select any of the sensor points and adjust thresholds & fan speed. It was evident from sensor readings that on my MP '13 the GPU 2 sensor was much hotter than 1, so I just adjusted the threshold way down. If it's heat related, that'll fix that. :)
Oliver Peters
on Aug 18, 2019 at 9:47:50 pm
I run into this constantly with Adobe apps (2013 MP, 8-core, D500). Usually when I have higher res media like 4K footage. I almost never have a problem with FCPX or Compressor. Resolve is so-so. Again more likely with higher res outputs. I also run Mac Fan Control cranked to max speed. It helps, but is not a cure.
- Oliver
Oliver Peters - oliverpeters.com
