trying out compound clips
COW Forums : Apple Final Cut Pro X Debates
Ben Scott
on Jul 12, 2011 at 8:32:59 pm
I have found it really tricky to figure out how to cut through multiple tracks at once with cmnd b, standard thing to do id expect
so I made a little movie to illustrate my point
if anyone can give me a reason why this doesnt work let me know
let me know if the video is a useful way to show this sort of error
compound clips getting cut and then broken apart
Tony Silanskas
Re: trying out compound clips
on Jul 13, 2011 at 7:37:07 am
The only success I have had (besides manually cutting each clip) is to the Compound Clip method. Agreed we need an easy way to do this. Also, I couldn't tell from you video if the Compound Clip method worked on not for you. Are you having problems with Compound Clip blades not going through all the clips? I haven't had this problem yet.
tony
http://www.HungryCliff.com
