4K and Mac HDMI
COW Forums : Apple Final Cut Pro X Debates
Oliver Peters
4K and Mac HDMI
on Jan 10, 2019 at 12:57:14 pm
More a Mac question than FCPX, but this forum seems about as good as any. Does anyone know whether the HDMI from a 2013 Mac Pro or a new iMac Pro (via a TB3-to-HDMI adapter) will support 4K/UHD to a 4K prosumer TV/monitor display? This would be using the a/v output signal from FCPX and/or Premiere Pro. I know HD is fine and I also know BMD and AJA make 4K devices, but I'm looking for a simpler solution in this case. TIA.
- Oliver
Oliver Peters - oliverpeters.com
Mathieu Ghekiere
Re: 4K and Mac HDMI
on Jan 10, 2019 at 3:40:38 pm
I thought the 2013 Mac Pro had HDMI 2.0 with 4K support, and since one of the FCPX updates a couple of years ago, FCPX read it as an A/V output. I'm pretty sure I connected 4K monitors to it in the past (but it's been a while ago)
https://mathieughekiere.wordpress.com
Jeremy Garchow
Re: 4K and Mac HDMI
on Jan 10, 2019 at 4:48:50 pm
You can get UHD (or 4k) 24, 25, or 30p to a consumer set, yes. iMac Pro may get you higher frame rates. You can see I can choose between AJA and the HDMI here:
FCPX:
Adobe:
There are Sony OLED consumer sets around here, and even 2013 rMBP can send 4k them out of the built-in HDMI
Oliver Peters
Re: 4K and Mac HDMI
on Jan 10, 2019 at 5:48:37 pm
Cool. Thanks.
- Oliver
Jeremy Garchow
Re: 4K and Mac HDMI
on Jan 10, 2019 at 5:58:09 pm
Sorry, for the Pr screen grab, the 4k out to the Sony monitor is the "Adobe Monitor 2" option even though the T-Tap is selected.
Bret Williams
Re: 4K and Mac HDMI
on Jan 13, 2019 at 3:15:56 pm
I’ve used it on 2012 iMac via TB2 to HDMI cable. I don’t know about the resolution, but in comparing the look from the HDMI vs BMD or AJA the HDMI out was never for anything but a quick way to view on a screen. The gamma was totally different and the colors were oversaturated. At the time it didn’t support interlacing and was 8 bit as well. Cant remember if it carried audio which helps keep audio in sync with picture by hooking up speakers to the audio output on my Flanders monitor. Unless things have changed I wouldn’t use it for color. It was also just kind of annoying how switching apps turned it back to a desktop and/or your mouse could still disappear to the AV out screen even though it was dedicated video. I’ll take a BMD or AJA any day. Prefer BMD geese days.
_______________________________________________________________________
http://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
Hang Tag http://bretfx.com/product/hang-tag
Overshoot Text http://bretfx.com/product/overshoot-text/
Outliner http://bretfx.com/product/outliner/
Clock Maker http://bretfx.com/product/bretfx-clock-maker/
