Did you remember to backup?
COW Forums : Apple Final Cut Pro X Debates
David Mathis
on Nov 14, 2018 at 5:16:06 am
Always have a backup strategy in place!
https://www.gizmodo.com.au/2018/11/nasty-adobe-bug-deleted-250000-worth-of-...
This can happen at anytime with any software.
Brett Sherman
Re: Did you remember to backup?
on Nov 14, 2018 at 12:49:56 pm
Corrupt project or media files? Absolutely. Deleting original files not associated with the project? Nope. This is a particularly egregious oversight by Adobe. I've never had this happen in the decades I've been editing on computers.
Yes backups are critical. And often it's user error that you need to recover from. Maintaining two copies of files is critical to avoid drive failure losses. So after you delete you project files off of your working drive array, that single backup is probably not enough.
Andrew Kimery
on Nov 14, 2018 at 3:40:07 pm
Also, it should be noted that this is an old, much talked about bug from the first release of CC 2017, it's just back in the news cycle because of the lawsuit.
[Brett Sherman] "This is a particularly egregious oversight by Adobe"
A previous OS update by Apple bricked external hard drives so, yeah, debilitating software bugs can come from anywhere.
Oliver Peters
on Nov 14, 2018 at 3:59:09 pm
The Adobe bug was fixed quickly and quite a while ago. It could also be avoided depending on your cache settings. It was the "automatic" settings that had the bug.
- Oliver
Oliver Peters - oliverpeters.com
greg janza
on Nov 14, 2018 at 4:03:48 pm
A good backup strategy is essential to a happy post life. And in the case of the guy who's suing Adobe because he lost hundreds of video files, he made two cardinal mistakes- not backing up his media and not creating a dedicated cache folder. I would venture to guess that he'll lose the suite against Adobe.
Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2019 13.0 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
David Mathis
on Nov 14, 2018 at 4:10:30 pm
I don’t see this person winning the lawsuit. Also, just saw this post in a user group in Facebook last night. I did not pay attention to the date but that was my error. My apologies in advance.
Andrew Kimery
on Nov 14, 2018 at 5:55:31 pm
I'm of mixed feeling about the lawsuit. On one hand, updates shouldn't destroy/brick users' data or hardware, but it happens enough that pretty much every update has a warning about the potential for data loss. And this guy had hundreds of thousands of dollars worth of videos and no backups? Really? In 2017? At some point users have to be responsible for taking care of their digital property when it's common knowledge than hardware and/or software failures could destroy data in an instant.
As I said, mixed feelings.
Brett Sherman
on Nov 15, 2018 at 1:14:54 pm
In this case, it's not 100% clear a backup would have saved him. Since it deleted the files without warning, he had no indication that they were gone. The only thing that would have alerted him to the fact is if he had opened the project and discovered the missing media. There are times when I go for months without opening the project. With one of my drive synchronization procedures, it would delete the files on the backup too.
And given that he couldn't recover files from the hard drive, I would suspect some time had passed between when it happened and when he discovered it. I could be wrong though.
I'd be covered because one of my backup drives archives deleted files. The other backup drive maintains an exact replica of the drive - files on that drive would be gone. But that one checks for corrupted files. It just goes to show that just having a backup procedure is not necessarily enough. It has to be well thought out to deal with any possibility.
And to be clear I don't support this lawsuit. I file it under the s&*t happens category. Adobe has egg on their face, but financially responsible? I don't think that's fair.
David Mathis
on Nov 15, 2018 at 4:48:26 pm
What about backing up and taking the backup drive offline? I agree that this lawsuit is just plain ridiculous. Adobe screwed up big time but they really should not be sued. Bottom line is never trust a computer.
Andrew Kimery
on Nov 15, 2018 at 4:52:33 pm
[Brett Sherman] "In this case, it's not 100% clear a backup would have saved him. Since it deleted the files without warning, he had no indication that they were gone."
I think this is the part of the conversation where were we get into the difference between redundant storage and backup storage. 😉
Keeping a mirrored copy of your active drives is redundant storage (which is good for recovering from a hardware failure) but the down side, as you note, is that any data corruption and/or deletion that happens on the active drives will find it's way into the mirrored set of drives. Backup solutions must be quarantined from active storage for this very reason. Backups should also be kept off site incase of a fire, lightening strike, natural disaster, etc.,.
A small documentary company I sometimes work keeps one copy of their data on their shared storage (ProMAX Studio), one on external HDDs that are only connected when doing backups, and a third on LTO tape that's kept in cold storage (the won't even wipe cards from the field until the files have made it to LTO). They spend a lot of money on data security (relatively speaking), but they spend exponentially more in the field capturing things that can't be recreated so to them it's a no brainer.
Brett Sherman
on Nov 17, 2018 at 1:54:46 pm
[Andrew Kimery] "I think this is the part of the conversation where were we get into the difference between redundant storage and backup storage."
And near-term and long-term archiving strategies! Almost everyone in this business only thinks about the former. Given my job I also have to think about the latter. Proprietary formats are death to long-term backups. I have years of Avid footage from the oughts that are for all practical purposes unaccessible. And I won't get into why I think LTO storage is a really shortsighted, awful idea in most cases.
Nick Meyers
on Nov 18, 2018 at 3:02:59 am
[Brett Sherman] "And I won't get into why I think LTO storage is a really shortsighted, awful idea in most cases."
Given the nature of this forum i'd say go for it!
I'd be interested to hear your take on it.
nick
Brett Sherman
on Nov 18, 2018 at 2:12:26 pm
While the data on tape may be solid and long-lasting, access to that data is not necessarily so. Accessing the data on the tape takes specialized and relatively rare hardware. And LTO usage is already dropping off. At some point in the not too distant future solid state storage and cloud storage is going to take over everything. Manufacturing of LTO drives will stop because it will not be economically viable. Because it's mechanical, existing devices will start to fail. And drivers will likely not be continued to be updated.
Secondly, because it stores data in a linear fashion, the storing of the data requires software. And retrieving the data requires the same software. In 20 years you have the possibility that the software won't be around. So you'll have a bunch of data on the tape, but difficulty accessing it.
People will say but hard drives are not reliable for long-term storage. And it is true that if you just want to make one copy, set it on a shelf and never think about it again then hard drives are not a good solution. But my point is no "set it on a shelf and forget about it" strategy is a real backup strategy. Hard drives are universally accessible. Data formats are standard. And will be supported much longer after they are abandoned. For example, IDE drives were abandoned about 15 years ago. But you can buy brand new IDE to USB adapters. And you have your choice of about 20 different ones.
But what about the costs? Isn't that more expensive? Probably. But that LTO drive and the tapes required are not cheap either. And if you have to hire someone to retrieve your data that's going to be exceedingly pricey. And how long are you really going to trust that LTO backup? 20 years? Time is going to be hard on LTO tapes too. Hard drive replacement is maybe slightly over twice as frequent. And guarantees real-time access to the data.
