FCPX 10.4.1 is out
COW Forums : Apple Final Cut Pro X Debates
Mathieu Ghekiere
FCPX 10.4.1 is out
on Apr 9, 2018 at 3:28:45 pm
I found the release notes here:
https://support.apple.com/en-us/HT201237
"Video noise reduction
Use the high quality, drag-and-drop noise reduction effect to reduce or eliminate grain and video noise
Easily change processing order by dragging the noise reduction effect in the Inspector"
Is the video noise reduction effect new? I don't remember that being available before.
https://mathieughekiere.wordpress.com
Craig Seeman
Re: FCPX 10.4.1 is out
on Apr 9, 2018 at 3:40:45 pm
And they "fixed" the Color Wheels it seems.
Color Correction
Color wheel sliders retain values at 100 IRE for white and 0 IRE for black, with the ability to move above and below using color correction controls
Simon Ubsdell
on Apr 9, 2018 at 4:05:28 pm
[Craig Seeman] "And they "fixed" the Color Wheels it seems."
Yes, this does seem to be fixed now.
But a quick look at the Midtones color wheel suggests there is a "kink" in the gamma curve that oversaturates the shadows ...
Very noticeable when you compare it to the Color Board.
So not completely fixed.
Simon Ubsdell
tokyo productions
hawaiki
Robin S. Kurz
on Apr 9, 2018 at 4:46:09 pm
[Simon Ubsdell] "Yes, this does seem to be fixed now."
Question is… does this affect (i.e. change) previous grades done with the wheels? One should assume YES, no?
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Jeremy Garchow
on Apr 9, 2018 at 5:15:34 pm
BTW, for the late adopters, this release requires High Sierra.
Simon Ubsdell
on Apr 9, 2018 at 5:29:19 pm
[Robin S. Kurz] "does this affect (i.e. change) previous grades done with the wheels?"
The good news is that when you update your Library to 10.4.1 the existing grades are kept intact.
This is presumably because 10.4.1 is running the "old version" of the color wheels in the background to make sure that none of your grades will be messed up when you update.
Edit: I have found however that exporting an XML from 10.4 to 10.4.1 does not transfer the color wheel information.
Simon Ubsdell
tokyo productions
hawaiki
Robin S. Kurz
on Apr 9, 2018 at 6:12:48 pm
Interesting. Thanks.
- RK
Youtube | Facebook
Robin S. Kurz
on Apr 10, 2018 at 2:59:22 pm
Here the official word btw:
Color Correction
* Color wheel sliders retain values at 100 IRE for white and 0 IRE for black, with the ability to move above and below using color correction controls
* Color board exposure parameters are consistent for Rec. 2020 PQ projects
* Keyframes are properly maintained when copying and pasting color wheel effects
* Custom white balance values are pasted correctly in Rec. 2020 HDR libraries
* View Masks selection displays the mask in the Viewer before color grading parameters are changed
- RK
Youtube | Facebook
Loren Risker
on Apr 9, 2018 at 5:26:10 pm
Did you see the noise reduction in the release notes? Did they take it out?
OutOfFocus.TV - Music Videos 24/7
Simon Ubsdell
on Apr 9, 2018 at 5:29:44 pm
[Loren Risker] "Did you see the noise reduction in the release notes? Did they take it out?"
There is no noise reduction in this release.
Simon Ubsdell
tokyo productions
hawaiki
Mathieu Ghekiere
on Apr 9, 2018 at 5:54:00 pm
The release notes talked about the noise reduction, I copied that text from the release notes. I didn't find the effect back in the effects panel and apparently it's taken out of the release notes too. Maybe just a matter of timing, with all the Prores RAW, that they add such an effect.
Paul Golden
on Apr 9, 2018 at 9:38:59 pm
Noise reduction was on a feature list earlier today but was removed a little while ago:
Craig Seeman
on Apr 9, 2018 at 10:44:11 pm
Must have been some very late "extraction." Odd to kill something from the release so late that it's there and gone in documents a day or so apart. Otherwise there was some internal miscommunication. Apple internal miscommunication? Perish the thought!
