How Do You Change Font Size In Final Cut Pro X?
COW Forums : Apple Final Cut Pro X Debates
John Manners
on Jul 10, 2011 at 8:23:38 pm
When you choose a title from the title browser, how do you change the size of the font? I can't find it anywhere! I also just tried to it with command+T, but that's cross dissolve.
Neil Patience
Re: How Do You Change Font Size In Final Cut Pro X?
on Jul 11, 2011 at 12:16:04 am
You can change the font size in the inspector window.
For example if you add a simple caption using the "middle" template from the title (T) tool this will give you a centred 2 line caption. Make sure you have the inspector visible which toggles on/off using option 4.
Assuming you have already placed it in your timeline simply double click it in the timeline and then use the title and text tabs at the top of the inspector to make all the adjustments you need.
best wishes
Neil
http://www.patience.tv
