Capturing VHS, drifting vertical sync
COW Forums : Archiving and Back-Up
Lauri Ahonen
on Jul 26, 2011 at 1:18:25 pm
I'm currently in the process capturing several hundred of VHS archived material as H.264 video. We are using Blackmagic Intensity Pro and Blackmagic H.264 Pro Encoders.
I would ask for your help with drifting vertical sync when capturing. I suppose that I would need a external sync generator of some sort. What kind of an unit would I require? The video is TBC synced S-Video PAL 576i signal.
M.D. Lauri Ahonen
Electronics and video processing enthusiast
Lauri Ahonen
Re: Capturing VHS, drifting vertical sync
on Jul 28, 2011 at 8:53:27 pm
I'm not having the problem with my other capture hardware. The problem must by with the H.264 encoder.
M.D. Lauri Ahonen
