Tape to LTO
COW Forums : Archiving and Back-Up
Neil Hurwitz
Tape to LTO
on Aug 23, 2013 at 4:20:51 pm
Here's the project
A few thousand tapes of different formats,
BetaSP, 1", DigiBeta, D2, D3 that need to be long term archived
Program lengths vary from a few minutes to 90 minutes.
All are finished shows.
I have all the various tape machines, so that's not an issue.
The D2 and D3 have serializers and I have the appropriate
units (DSP's) to convert the BetaSP and 1" to 601 SDI
I want to be able to do this without first loading into
a NLE system and to make the workflow as close to old
fashioned DigiBeta cloning as possible
Two ideas are
1. to dub everything to P2 and then go P2 to LTO
2. to dub everything to SSD's via BlackMagic and then
go from SSD to LTO
What say you all
Looking for workflow ideas and hardware recommendations?
I'm looking for a simple, easy to operate set up.
Hardware budget is around 10,000 not including P2 equipment
but including any Blackmagic gear (I have plenty of access
to P2) Budget can expand a bit if Blackmagic workflow is significantly better.
As a monkey wrench client might want all shows conveted to HD
in the process for which we would put a Teranex in the signal Chain
Thanx all in advance
Tim Jones
Re: Tape to LTO
on Aug 23, 2013 at 5:55:22 pm
I'd go with option 2 - for 2 reasons:
1: You will be able to work very efficiently with the media on the SSD drives
2: Archiving the data from the SSDs to the LTO drive will be much faster than from the P2 media.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Dave Barnard
Re: Tape to LTO
on Aug 29, 2013 at 12:21:35 pm
I would seriously consider using RAID storage and a Media Asset Management system before archiving to LTO, this will be critical in making use of your archive in the future
I'm working with a client who has 2500 hours of digitised tape material, this is certainly a key issue for them
Dave Barnard
cinedigital, London
Tim Jones
Re: Tape to LTO
on Sep 19, 2013 at 6:49:45 pm
@Dave - I agree whole-heartedly about DAM / MAM for management. However, it shouldn't be looked at as an either-or situation. There are many existing and up and coming DAM / MAM solutions that include LTO tape archival integrated within the management workflow.
As one example, using CatDV with DAX Broadcast Archive and BRU Server allows a team to do all of the metadata management that would be expected while providing archival and off lining services as a simple mouse click within the management workflow - no IT staff required :) .
Tim
Tim Jones
