Cache-a tape adding more files to LTO5 after tape removal
COW Forums : Archiving and Back-Up
Shannon Rowe
on Apr 26, 2013 at 2:01:57 pm
Hi, I just need to clarify that after we archive to an LTO5 tape and remove the tape, can we reload the same tape and add more files to that tape? Or, will it overwrite what already exists on that tape? I have read conflicting information on this.
Shannon
Tom Goldberg
Re: Cache-a tape adding more files to LTO5 after tape removal
on Apr 29, 2013 at 4:02:43 pm
Shannon,
When using Cache-A gear, you will absolutely never overwrite any data on a tape unless you erase it.
If you check the Tape Information dialog to ensure that you will have plenty of space for whatever you want to add, you will have no issues in this regard. (We do recommend you leave 5-10% of the capacity of each tape to ensure you don't end up overfilling.)
Tom Goldberg
Cache-A Corporation
433 Park Point Drive #285
Golden, CO 80401
mailto:tom.goldberg@cache-a.com
http://cache-a.com
