retreive info from LTO
COW Forums : Archiving and Back-Up
Hernan Caratozzolo
on Jun 8, 2011 at 1:34:49 pm
Hi
I would like to know if I need the same software that someone use to archieve info inside the LTO to retieve the data.
More details: I am looking at Cache-A, Tolis + HP; Should the user buy the same software that I use to archieve to retrieve the info?
Regards
Hernán.
Andrew Richards
Re: retreive info from LTO
on Jun 9, 2011 at 4:59:06 pm
Most likely you will need the same software, unless the LTOs were written with standard TAR (Cache-A does this by default) or the new LTFS (which, as far as I know, has been added as an option by both Tolis and Cache-A for LTO-5 setups). Almost anything else will require the same software that wrote the tape to read the tape. Check with individual vendors to know for sure.
Best,
Andy Richards
VP of Product Development
Keeper Technology
Hernan Caratozzolo
on Jun 13, 2011 at 1:08:46 pm
Thank You very much for your time, answering this basic stuff.
Regards,
Hernán.
