LTO 5 on MacPro2,1
COW Forums : Archiving and Back-Up
steve voyk
LTO 5 on MacPro2,1
on Jan 31, 2013 at 3:45:36 pm
Hi guys,
Anyone know if I will have any issues using an Atto H680 SAS card on a MacPro 2,1 system ?
I would be archiving media from the MAcPro's 2 internal drives (RAID0) to the LTO5 unit, via BRU PE software (LTFS).
Would this old 2,1 have the same speeds as a newer 2012 MacPro in regards to LTO archiving (ie 32bit vs 64bit and faster bus speeds etc.)?
Cheers,
Tim Jones
Re: LTO 5 on MacPro2,1
on Jan 31, 2013 at 4:44:46 pm
A 2,1 will work fine. You will need to run the EFI Configuration utility to insure that the H680's slot is at least an x4 lane slot, but other wise you'll be fine. We actually test on an original 1,1 running 10.4.11 as our base model test environment.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
