Looking for Workflow - Backing Up Many TB to Quantum Tape Drive
COW Forums : Archiving and Back-Up
Ian Smith
on Jan 2, 2013 at 8:27:28 pm
I am trying to find a proper solution for backing up TB of live projects, and past projects.
- In more detail:
I am working on a Mac OSX Mountain Lion (10.8.2)
Final Cut Studio Pro 7 Suite
I primarily store and work off a CalDigit HDPro (12TB) connected via e-SATA
Inside the Mac I have a 1T drive I'm calling "Staging Archive", as I'm using this drive to move files to in which I plan to back up to tape. A few projects are old enough I may back them up to two tapes and then just remove them from the machine.
For file transfer management and travel purposes, I also have two external CalDigit drives. 1=2T; 2=4T
Goal:
I need to free up space on the CalDigit HDPro by moving older projects onto 2 or more tapes each. I will not be able to keep up with purchasing more hard drives with the amount of files coming in.
Q:
I am looking for a proper workflow in backing up projects to 1.5T tapes. My biggest challenge is figuring out how to organize for the backing up process. For each 1.5T tape, should I be moving up to 1.5T of project files into a folder, and then backing that folder up? Any suggestions or ideas are greatly appreciated.
Ian
Ian Smith
Tim Jones
Re: Looking for Workflow - Backing Up Many TB to Quantum Tape Drive
on Jan 2, 2013 at 9:36:57 pm
With BRU Producer's Edition, your workflow is drag, drop, click. BRU PE writes your data to tape using the folder layout that you have on your disk(s) and then allows you to search all known archives by those same folder / filename parameters for restoring a single clip, a folder, or an entire archive. Additionally, its catalog format are gzipped, pipe-delimited flat text files that are easily imported into tools such as Excel, Numbers, CD Finder or custom database apps if you need to track clip info outside of the BRU PE environment.
BRU PE will work with your existing Quantum LTO-5 drive and provide a very reliable verification capability to insure that the data is safely stored on the tapes (or even make multiple tapes of the same data) so that you can safely remove the original data from your working drives to free up space.
If you haven't taken a look at it yet, you can download a fully functional 30 day demo from the Production Backup website.
http://www.productionbackup.com
Tim
Tim Jones
CTO - TOLIS Group, Inc.
BRU ... because it's the RESTORE that matters!
Ian Smith
on Jan 2, 2013 at 10:38:29 pm
Thank you for your assistance!
I am backing up the CalDigit HDPro as I write. I have selected the HDPro array, and using BRU PE, I now have it backing up.
This will take up about 5 1.5T tapes in all. As I make changes to projects currently being backed up, what do I need to do to reassure these changes are also backed up? Will I select the "append" option, and tell it to backup? I assume BRU PE will ask me for specific tapes in order to update these changes? Or am I completely misunderstanding how this should work?
Ian
Ian Smith
Tim Jones
on Jan 3, 2013 at 6:44:33 pm
Hi Ian,
Glad that you're giving BRU PE a workout!
You would use BRU PE's "incremental" selection option from the Advanced mode to only add the changed files (BRU will do this automatically). Check out the manual in chapter 6 for specifics.
These incremental operations can be appended to tapes, or written to new tapes. For all BRU products, there is no required relationship between full archives/backups and incremental archives/backups. You could write you full jobs to LTO-5 media and then write your incremental jobs to another eSATA or SAS drive for temporary storage until you next run a full job for that data.
Tim
Tim Jones
Ian Smith
on Jan 3, 2013 at 7:03:53 pm
That's really good news to hear, and helpful information!
Currently, I'm working on figuring out why BRU isn't recognizing it's own tape backup when trying to verify. I ran a backup of the entire CalDigit HDPro. It estimated 5 tapes. It ran three before beginning a verification process. It then asked for the first media set, but then stated it was either an empty tape, or non-BRU data. - I'm attempting the same backup, and selected to "overwrite" all existing data.
It's possible I grabbed a tape I thought was empty, but was from my first go-round when I used Retrospect. I found that software to no longer be supported, so I switched to BRU-PE. Now I'm working to back everything up using it.
Ian
Ian Smith
Tim Jones
on Jan 3, 2013 at 7:11:02 pm
You can also check the tapes manually -
Leave BRU PE waiting for the tape and open a Terminal. In the terminal, type:
tapectl header | bru -gf -
Does that recognize the tape as a BRU tape?
Tim
Tim Jones
