Disaster Recovery: Importing Cache-A catalog into new LTO5 tape deck?
COW Forums : Archiving and Back-Up
Kyle Heidenreich
on Jul 3, 2018 at 10:55:33 pm
Hey all,
Our old Cache-A ProCache LTO 5 unit finally kicked the bucket. Fortunately I have an up to date .tgz file of the catalog backup, and also I've just found a PrimeCache LTO 5 deck to read our tape collection.
Problem: The Prime Cache has trouble finding the Table of Contents on some of our tapes that I know worked just fine in the old unit. It says media may be corrupt....Anyway, I'm wondering how I would go about importing my back up catalog...would that fix my table of contents issue?
Kyle
Tom Goldberg
Re: Disaster Recovery: Importing Cache-A catalog into new LTO5 tape deck?
on Jul 4, 2018 at 3:20:32 pm
Kyle,
On Cache-A units, the catalog is not used when reading tapes, it is only there so humans can know what is on each tape. So importing your backup catalog wouldn't help (even if it were possible, which it no longer is).
Any reading of a tape uses the table of contents on that tape to access files. If the loaner Prime-Cache can't read it, either there is a problem with the unit or with the tape. Following are some things to try.
If the tapes are written with LTFS, you might want to try a more up-to-date LTFS system to recover them. If they are written as tar tapes, there is a procedure available to recover all files from any Cache-A tar tape - you can find that here:
http://www.tomgoldberg.net/Cache-A/CATechBrief-ReadCAtar.pdf
also a set of instructions for using terminal commands on a Cache-A is here:
http://www.tomgoldberg.net/Cache-A/CATechBrief-CommandLine.pdf
and if you did want a copy of the catalog, these instructions will work on your old Pro-Cache assuming it will boot:
http://www.tomgoldberg.net/Cache-A/CATechBrief-catalog-export.pdf
I hope this helps,
Tom
Tom Goldberg
TGCS
30201 Rainbow Hill Rd.
Evergreen, CO 80439
mailto:tomgoldberg@gmail.com
http://tomgoldberg.net
Ed Murphy
on Aug 21, 2018 at 5:08:58 pm
Hi Tom,
Do you know of any way to recover/export the catalog without using the Pro-Cache?
Ours kicked the bucket too and it will not boot, nor can I restore it with the recovery USB stick, but I do have a backup of the .tgz catalog file.
I really want to be able to find some way to still search our catalog, instead of having to manually restore 100+ LTO5 tapes in order to recreate it.
Thank you!
Ed Murphy
Senior Editor / Technical Director
David Lynch Foundation Television
Tom Goldberg
on Aug 23, 2018 at 5:37:32 pm
Hi Ed,
Unfortunately, the catalog backup .tgz file is no use without a Cache-A. The database contents are in there but hashed and must be loaded back into a working unit. If your Pro-Cache will boot from the recovery stick, it would be possible to use it to restore this data. If you want to pursue this, please contact me directly off forum.
Tom Goldberg
TGCS
Evergreen, CO 80439
Martin Greenwood
on Aug 24, 2018 at 8:43:23 am
Hi Ed,
We're looking at importing Cache-A metadata into our LTFS app. If you want to email a link to your backup tgz then we can take a look and see what is possible.
Martin Greenwood
martin@yoyotta.com
CTO
YoYotta.com
Tom Goldberg
on Aug 24, 2018 at 3:07:03 pm
Very Cool Martin, let us all know how that goes.
Tom Goldberg
TGCS
Evergreen, CO 80439
Ed Murphy
on Aug 27, 2018 at 8:44:43 pm
Thank you both, Tom and Martin!
Martin, that is great news, as I am currently using the demo of YoYotta and liking it. I was able to fully restore a Cache-A tar LTO5 tape with it, but to be able to access and/or recreate our existing catalog would mean a world of difference!
Tom, I will certainly pursue that suggestion with you depending on or in tandem with what Martin has to say about my catalog file.
I'll email you each with my specifics by tomorrow at the latest.
I will also follow up here for others with any interesting results we find.
Ed Murphy
