Pairing Raws and jpgs from different folders
COW Forums : Archiving and Back-Up
Stefano Neri
on Jul 22, 2017 at 12:26:14 pm
Hi everybody,
Last week a customer of mine had to choose some photos from a work.
He can't manage raw, so I sent to him the jpg version of the photos : he selected a huge amount of photos (~4500).
Now I have to pair the selected Jpgs to the corresponding Raw. They've the same name (es . IMG4813.cr2 and IMG4813.jpg) and are located in two different folders.
Is there a way to automatically match them,so I could easily the files I don't need?
Actually I run on a MacBook Pro Retina,but I can also use Windows on it.
Thanks alot
Stefano
Dougal Matthews
Re: Pairing Raws and jpgs from different folders
on Jul 25, 2017 at 12:05:34 pm
hi
I can highly recommend beyond compare as a file comparison tool it available on pc mac and linux will compare folders and can handle comparing filenames with different extensions
You can even compare 2 folders and merge into a 3rd
you can see more about the features here
http://www.scootersoftware.com/features.php
I hope this helps you achieve your aims
good luck Dougal
Improvise Adapt and Overcome
