New BRU Release..sudo restore?
COW Forums : Archiving and Back-Up
Dan Olsen
on Mar 8, 2017 at 2:18:47 am
Tried running two archives on the new 3.1.23 rel and froze both times immediately upon hitting "start archive" so I thought I'd give some restores a shot--only to see this
Never seen that before! Anyone else having the same issue? Am I doing something wrong?
James Vorley
Re: New BRU Release..sudo restore?
on Mar 8, 2017 at 4:11:05 pm
Exact same behaviour here after updating.
Verifies still working from the command line.
Tim Jones
on Mar 8, 2017 at 6:05:05 pm
The team is working on this.
Are both of you running on 10.11.6 by any chance?
In the meantime, you can skip authenticating at the start and it will run in your user's space. This will work unless you're actually trying to backup and restore your system volume (which requires authentication).
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
James Vorley
on Mar 8, 2017 at 6:20:52 pm
Skipping authenticating worked a treat, thanks Tim.
On 10.10.5 here.
Cheers
James
Dan Olsen
on Mar 8, 2017 at 6:56:56 pm
Thanks Tim, I'm actually on 10.10.5
Tim Jones
on Mar 8, 2017 at 9:41:59 pm
Hi Guys,
3.1.23 build 357 is now posted on the download site. It was a bad header file pointing to the wrong API ...
Tim
Tim Jones
