The fastest and largest 2,5" form factor solution (with spinning drives).
COW Forums : Archiving and Back-Up
Karel Voners
on Feb 21, 2017 at 6:08:17 pm
I'm looking for a fast 2,5" 4TB+ solution to copy 4K red rushes. SSD's are in use but they need to be offloaded at the end of the day and i'm looking for a portable solution that is reasonably fast. The average shooting day is 500-800 GB and this needs to copied twice.
I tested the Seagate Fast STDA4000200, a 4TB drive that reaches speeds of 200 MB/s.
I'm wondering if anyone knows what else is out there? Better or faster solutions?
Many Thanks!
K.
David Roth Weiss
Re: The fastest and largest 2,5" form factor solution (with spinning drives).
on Feb 21, 2017 at 6:29:05 pm
You didn't say how you're connecting your drives, but more importantly, you will never find a single spinning hard drive faster than the 200MB/sec you've already found. If you want faster throughout you'll need a RAID with two or more drives striped together. A good rule of thumb to remember is, every time you double the number of drives in a striped set you effectively double the throughput.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Tim Jones
on Feb 21, 2017 at 7:20:12 pm
I concur with David - more spindles = better speed.
You don't mention how you wish to connect, but of you have a SAS HBA with an available port (4 channels), you could use something like this chassis from iStarUSA:
https://www.amazon.com/iStarUSA-SATA-Hot-Swap-Cage-BPU-350SATA-RED/dp/B003Y...
Populate 1-4 of the bays with that Seagate drive and stripe them. You would then connect the ports on the back of the chassis to the SAS HBA Port with a cable like this:
https://www.amazon.com/CableCreation-External-26pin-SFF-8088-Cable/dp/B013G...
Or, if you can go to 3.5" drives, you could use something like the SansDigital XR4T and get your storage out to 40TB and over 750MB/sec sustainable with Seagate's 10TB enterprise class drives (we use a number of these in our lab).
https://www.amazon.com/Sans-Digital-TR4X-Storage-Enclosure/dp/B002AKKDBY/
https://www.amazon.com/Seagate-Enterprise-Capacity-Cache-Internal-ST10000NM...
If you are limited by USB connectivity, you could use something like this as your chassis for 3.5" drives:
https://www.amazon.com/Mediasonic-External-Drive-Enclosure-HFR2-SU3S2/dp/B0...
Or This for 2.5" drives:
https://www.amazon.com/Noontec-TerraMaster-D5-300-Enclosure-Support-Diskles...
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Neil Sadwelkar
on Feb 23, 2017 at 11:34:38 am
The iStar HDD cage that's mentioned by Tim is not an external device. It goes inside a PC cabinet and needs an SMPS to power it. and it uses 3.5" drives.
For 2.5" drives you could consider a 2.5" RAID case from Akitio which has removable 2.5" drives.
Like this one
Akitio Thunder2 Quad Mini
https://www.amazon.com/Akitio-TBQM-TIAA-AKTU-Thunder2-Quad-Mini/dp/B00VJ4IW...
It has no RAID capabilities, however.
There's the Promise Pegasus M4 which is tiny and supports 2.5" SSDs and drives.
https://www.bhphotovideo.com/c/product/1046491-REG/promise_technology_p2m4h...
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
