Bru PE on El Capitan not Importing tapes
COW Forums : Archiving and Back-Up
Bruce Ingram
on Feb 22, 2016 at 7:14:54 pm
Hello, was hoping anyone here had the same experience and possible solution to my problem. We are using the latest Bru PE version and while I can archive tapes and restore from those tapes, I am unable to use the Import Tool to create catalogs for some older tapes (LTO4 created using Bru a couple of years ago). It goes through all the motions and says it has completed but once in Bru PE the tape set lists "No Archive Catalog found". I've attempted to do import several tapes (4 in all) from different archive dates and get the same result. It was working just fine under the previous OS, so I'm suspecting issues with Bru PE and El Capitan.
If anyone has any insight or advice, it would be greatly appreciated!
Sam Lee
Re: Bru PE on El Capitan not Importing tapes
on Feb 25, 2016 at 2:14:41 am
I had this unable to import catalog problem with 3.15 to 3.16. But the latest 3.17 works fine in El Capitan OSX. It will show up in the Restore. Prior to this nothing appeared in the Restore.
I always export the catalog .zip file whenever the archive is completed. This saves a step if there's ever a need to reimport the catalog from the LTO media.
Ben Hilton
on Jul 28, 2016 at 1:05:54 pm
I'm having this exact issue on 3.1.19 - did you manage to resolve it?
