Tape error
COW Forums : Archiving and Back-Up
Aaron Duprey
Tape error
on Oct 27, 2015 at 8:50:31 pm
Using Cache-A / LTO-5
A tape that I've just erased is giving me errors when I try to reformat it. Here's the message:
_______________
145 - Table './catalog/file' is marked as crashed and should be repaired
SELECT filename,id,parent_id,type,size,mtime FROM file WHERE (toc_id=143 && parent_id=0) GROUP BY (filename) ORDER BY filename,mtime DESC;
[TEP STOP]
__________________
Can anyone decipher this for me?
Tom Goldberg
Re: Tape error
on Oct 28, 2015 at 2:57:35 pm
Aaron,
That message tells you that the Cache-A's internal database of all catalogs has become corrupted (basically a mySQL error). This usually can be easily repaired by ProMax support or by anyone logging in through Cache-A's maintenance login. The process is not difficult but any errors could cause bigger problems.
I recommend that you contact ProMax support to get this fixed, but if that doesn't work for you and you are comfortable using a command line, please send me an email directly and I'll provide the commands.
Tom Goldberg
TGCS
30201 Rainbow Hill Rd.
Evergreen, CO 80439
mailto:tomgoldberg@gmail.com
http://tomgoldberg.net
Aaron Duprey
Re: Tape error
on Oct 28, 2015 at 4:21:32 pm
E-mail coming your way, Tom. Thanks.
