Expansion Slot Utility says my Atto H680 is not working at full speed
COW Forums : Archiving and Back-Up
Enrique Londaits
on May 1, 2015 at 5:22:52 pm
Hi eveybody. I just installed an ATTO H680 in my 2009 MacPro, which I intend to use with an external LTO 6 drive.
As soon as I rebooted I got a message that said my recently installed card was not working at full speed,
and the Expansion Slot Utility came up. Should I change this configuration or just let it be? Thanks in advance
Enrique Londaits
Martin Greenwood
Re: Expansion Slot Utility says my Atto H680 is not working at full speed
on May 1, 2015 at 6:32:12 pm
Hi Enrique,
I think it's in slot 2 which is a x1 slot and both your x4 slots have x1 cards installed.
So I would swap slot 2 with the card in slot 3 or slot 4.
Best,
Martin
CTO
YoYotta
Tim Jones
on May 1, 2015 at 6:37:37 pm
Martin's correct - swap the cards in slots 2 and 4 and then select Profile 1. This is the way that our 1,1 test units are configured. Quadro 4800 in slot 1, Sonnet PCIe Qio card in slot 2, USB 3 card in slot 3 and ATTO H680 or R680 in slot 4.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Enrique Londaits
on May 1, 2015 at 7:53:44 pm
Thank you guys. That did it! Best to you
