Cache-a Catalog Corrupted
COW Forums : Archiving and Back-Up
Florentin Genot
on Oct 28, 2014 at 10:57:34 am
I bought a LTO6 pro cache-a 1 years ago and It works fine.
But I got a big problem this morning.
The catalog seems to be corrupted. Each time I access to any tape in the catalog I have this message (with a different "toc_id" number):
145 - Table './catalog/file' is marked as crashed and should be repaired
SELECT filename,id,parent_id,type,size,mtime FROM file WHERE (toc_id=96 && parent_id=0) GROUP BY (filename) ORDER BY filename,mtime DESC;
[TEP STOP]
Any idea to repair it?
Florentin Genot
florentin@saya.fr
Tel : +33 1 42 21 10 58
Florentin Genot
Re: Cache-a Catalog Corrupted
on Oct 28, 2014 at 6:08:57 pm
The support gave me the procedure to rebuild the databases.
The problem is fixed now.
Florentin Genot
florentin@saya.fr
Michael Hauso
on Nov 20, 2014 at 3:44:41 am
Is the procedure something you can share? Or was it too specific to your system for me to use it? I am having the same issue.
Florentin Genot
on Nov 26, 2014 at 4:46:15 pm
Ooops, I just missed your message.
The procedure is pretty simple. you have to repair your database using these command lines :
8226_databserepair.txt.zip
Here is the procedure to access the command line by SSH :
8227_catechbriefcommandline.pdf.zip
Regards,
Florentin
Mo Abdulla
on Jul 1, 2015 at 11:36:36 am
Just had the same issue on our 2 month old Promax LTO 6 machine and just to confirm that this fix sorted it.
Thank you!
Mo
bill morrison
on Oct 25, 2015 at 10:24:52 am
I've had the same problem and came across this post. Tried to issue the command 8226-........ but it came back with unknown command. Can someone advise where and how I'm supposed to use this procedure.
bill morrison
on Oct 27, 2015 at 8:36:57 pm
Forget the above post. I've figured it out and got it working. Thanks for the info
