APS Battery Backing up a Mac Pro and Pegasus Raid
COW Forums : Archiving and Back-Up
Peter Vandall
on Jul 4, 2014 at 8:44:28 pm
Hi there,
Can someone help me with the proper hook up to a mac pro and a pegasus raid to an APS? I noticed on the back of the APS there are different outlets marked as battery back up, surge protection, and master.
My assumption was that all the outlets would be backed up by the battery? Ideally if I lost power I would want my raid and mac pro to stay on. But if that isn't the case, what would you recommend for a proper hook up?
Pete
Tim Jones
Re: APS Battery Backing up a Mac Pro and Pegasus Raid
on Jul 5, 2014 at 5:05:36 pm
Only the plugs marked with the battery are backed up in case of power outage.
The others are just like a surge protector.
Be aware that for proper coverage of your RAID system, you should have a minimum of 1,250VA of power. Otherwise, you may find that the RAID draws down the battery before the Mac can safely shut down.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
