LTFS: Can't copy large files
COW Forums : Archiving and Back-Up
Matt Babcock
on Mar 26, 2014 at 3:30:14 am
Hi Everyone,
I'm trying to use a new mac pro running 10.9.2 to archive to LTFS. I've gotten through formatting the tape and mounting it. I can successfully copy small files, under 4gb, the the tape but anything over that fails and gives me the following error, can't be copied because it is too large for the volume's format.
One of the dozen times I've tried the tape mounted a bit differently and sort of worked. Instead of mounting as the name I used it mounted as volumename(ltfs) even though I mounted it as the barcode but when trying to copy files it was going at a crawl, 10gb an hour. Of course I had two terminal windows open when I did this so I don't know exactly what I did differently that time. Sigh.
Formatting Command: mkltfs -d 0 -f -n lto5 -r size=2M/name=metadata.xml
I've tried mounting both in /Volumes and in /mnt
LTO6 drive using an LTO5 tape.
My ltfs version is 2.1.1
OSXFUSE is 2.6.2
Please help!
Tim Jones
Re: LTFS: Can't copy large files
on Mar 26, 2014 at 3:23:04 pm
One more thing for details -
When you execute that ltfs command to mount the volume, there are a lot of lines spit out in the terminal window that look like this:
LTFS14000I LTFS starting, LTFS version 2.0.0, log level 2
LTFS14058I LTFS Format Specification version 2.0.0
LTFS14063I Sync type is "time", Sync time is 300 sec
LTFS20013I Drive type is HP LTO6, serial number is XXXXXXXXXX
LTFS17160I Maximum device block size is 524288
LTFS11005I Mounting the volume
LTFS12015I Attempting to load the medium
LTFS11031I Volume mounted successfully
LTFS14029I Ready to receive filesystem requests
Change your mount command to spit out a bit more detail and then try to copy the failing files over to the tape:
ltfs /Volumes/SampleLTFSMount/ -o trace,eject,volname="Sample LTFS Mount",devname=0
LTFS20028D Found device class 0x5AC92550 at index 0
LTFS20010D SCSI request: [ 12 00 00 00 F0 00 ] Requested length=240
LTFS20011D SCSI outcome: Driver status=0x00 SCSI status=0x00 Actual length=96
LTFS20084D Drive identification is 'Ultrium 6-SCSI '
LTFS20010D SCSI request: [ 12 01 80 00 20 00 ] Requested length=32
LTFS20011D SCSI outcome: Driver status=0x00 SCSI status=0x00 Actual length=14
After you copy a file that normally fails, scroll through the output until you find the filename that you tried to copy and you'll see output that looks like this:
LTFS20057D Backend capacity part0: (36750, 36750)
LTFS20057D Backend capacity part1: (1384552, 1396529)
LTFS14031D FUSE getattr for '/Minimus the Poet Final.fcpxml'
LTFS14051D FUSE getxattr '/' (name='com.apple.FinderInfo')
LTFS14040D FUSE create file '/Minimus the Poet Final.fcpxml'
LTFS20010D SCSI request: [ 00 00 00 00 00 00 ] Requested length=0
LTFS20011D SCSI outcome: Driver status=0x00 SCSI status=0x00 Actual length=0
LTFS14030D FUSE fgetattr for '/Minimus the Poet Final.fcpxml'
LTFS14031D FUSE getattr for '/._Minimus the Poet Final.fcpxml'
LTFS14037D FUSE flush '/Minimus the Poet Final.fcpxml'
LTFS14035D FUSE release file '/Minimus the Poet Final.fcpxml'
Walk through that text to find the actual error condition that is being reported. Maybe that will give us more detail on why it's failing.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Tim Jones
on Mar 26, 2014 at 3:50:53 pm
One more thought about the formatting step -
Try formatting with this command sequence:
mkltfs -f -d 0 -s RR0001 -r "size=2M/name=Manifest.xml" -n "Red Rock Deliverables"
(of course, change the serial number and volume name to suit your needs..).
Now mount that new volume and copy the files that are currently erroring.
Tim
Tim Jones
Matt Babcock
on Mar 26, 2014 at 4:46:14 pm
Here is the output from my Formatting:
Red-Rock-Films-Server:~ RRFHomeServer$ mkltfs -f -d 0 -s RR0001 -r "size=2M/name=Manifest.xml" -n "Red Rock Deliverables"
LTFS15000I Starting mkltfs, HP StoreOpen Standalone version 2.1.1, log level 2
LTFS15041I Launched by "mkltfs -f -d 0 -s RR0001 -r size=2M/name=Manifest.xml -n Red Rock Deliverables"
LTFS15042I This binary is built for Mac OS X
LTFS15043I GCC version is 4.2.1 (Apple Inc. build 5646)
LTFS17087I Kernel version: Darwin Kernel Version 13.1.0: Thu Jan 16 19:40:37 PST 2014; root:xnu-2422.90.20~2/RELEASE_X86_64
LTFS15003I Formatting device '0'
LTFS15004I LTFS volume blocksize: 524288
LTFS15005I Index partition placement policy: size=2M/name=Manifest.xml
LTFS17085I Plugin: Loading "ltotape" driver
LTFS20013I Drive type is HP LTO6, serial number is HU14030UU1
LTFS15010I Creating data partition b on SCSI partition 1
LTFS15011I Creating index partition a on SCSI partition 0
LTFS17165I Resetting the medium's capacity proportion
LTFS11097I Partitioning the medium
LTFS11100I Writing label to partition b
LTFS11278I Writing index to partition b
LTFS11100I Writing label to partition a
LTFS11278I Writing index to partition a
LTFS15013I Volume UUID is: e4704e1a-f2eb-46b5-89c7-f3ee705f0f8e
LTFS15019I Volume capacity is 1445 GB
LTFS20076I Triggering drive diagnostic dump
LTFS20096I Diagnostic dump complete
LTFS15024I Medium formatted successfully
Matt Babcock
on Mar 26, 2014 at 4:47:17 pm
Here is the output from the mounting:
Red-Rock-Films-Server:~ RRFHomeServer$ ltfs /Volumes/Red\ Rock\ Deliverables/
LTFS14000I LTFS starting, HP StoreOpen Standalone version 2.1.1, log level 2
LTFS14058I LTFS Format Specification version 2.1.0
LTFS14104I Launched by "ltfs /Volumes/Red Rock Deliverables/"
LTFS14105I This binary is built for Mac OS X
LTFS14106I GCC version is 4.2.1 (Apple Inc. build 5646)
LTFS17085I Plugin: Loading "unified" iosched
LTFS14111I Initial setup completed successfully
LTFS14112I Invoke 'mount' command to check the result of final setup
LTFS14113I Specified mount point is listed if succeeded
Matt Babcock
on Mar 26, 2014 at 4:47:49 pm
Copying through the GUI I get the same error message as before about it being too large for the format.
Seth Goldin
on Aug 25, 2015 at 7:09:10 pm
Matt,
Did you ever figure this out? I'm having a similar issue.
Seth Goldin
Freethink Media
Washington, DC
al ellis
on Apr 6, 2017 at 10:39:32 am
i've just got the same thing, been working fine then no go, its like the old 4gb file limit thing. did anyone find a solution?
thanks al
Francis Newall
on Jun 20, 2017 at 1:54:22 pm
Hi Al,
I've just posted the solution in my other thread.
By going on here (https://community.hpe.com/t5/Tape-Libraries-and-Drives/HPE-StoreOpen-on-Mac-no-longer-can-store-files-4GB/td-p/6959897), you can see the most recent solution is simply to exit Adobe Creative Cloud. My 4+GB files are now copying perfectly straightaway.
Many thanks and kind regards,
Francis
Daniel Thompson-Hoare
on May 24, 2017 at 3:36:04 pm
I am also having this issue and haven't been able to get anywhere in resolving it. HP Enterprise support are also hopeless it seems.
Have tried my LTO Ultrium 15000 with LTO-7 drives on multiple computers with both OSX and Windows with the same results. It worked just fine with >4GB file sizes last week, now it displays that same error.
Has any progress been made towards resolving this?
Matt Babcock
on May 24, 2017 at 7:22:26 pm
I'll be honest this one is a bit older than my recall goes back. I did eventually solve it, i think i had to start fresh and uninstall everything and start over. Subsequently we started using Pre-Roll post and all our LTFS headaches went away. I also recently had a lot of success using the LTFS configurator tool from I think HP.
Basically once I stopped trying to format tapes via command line everything just started working for me.
on May 24, 2017 at 10:10:42 pm
Oh that's interesting, unfortunately reinstalling everything hasn't worked for us, nor using multiple computers or the GUI software to format, still get that same file format limit error ☹ very annoying indeed.
Interesting enough I didn't even know you could use Terminal to format/operate the drives until we started having this issue and I began researching it.
Is Pre-Roll post and alternative to OSXFUSE/HPE software?
Hari Krishna Pune
on Jan 22, 2019 at 6:05:19 am
Hello,
The post seems like very old. But I am also getting the same error here with both the hp half height and full height external drive. Did anyone find a solution for this issue using the hp gui software?
It was fine with my earlier IBM drive. I am only getting the issue with hp drive and hp ltfs.
Hp ltfs version: 3.2.0
Mac OS: 10.11.6 El Captain
sas card: Atto R680
Sas drivers : 3.7.6 (october 2017)
HARI KRISHNA PUNE
FCP EDITOR & ARCHIVE MANAGER
on Jan 22, 2019 at 6:22:39 am
For us, it was Adobe Creative Cloud interfering with it. Quitting Creative Cloud from activity monitor resolved the issue.
