a problem mapping with HP store open
COW Forums : Archiving and Back-Up
Hadar Kre
on Jan 29, 2014 at 12:03:22 pm
I recently installed HP store open on another machine
in the configuration tool, when I'm tryign to mape the tape I'm getting an error about HBA driver
in the machine all the drivers are updated and working fine
OS: Windows server 2008 R2 x64
(the tape works fine with backupexec)
LTO5 tape (HP)
anyone have an idea how to fix it?
Frank Gothmann
Re: a problem mapping with HP store open
on Jan 29, 2014 at 9:39:13 pm
LTFS has special requirements when it comes to hbas and can be picky. What card to do you have? What driver?
"You also agree that you will not use these products for... the development, design, manufacture or production of nuclear, missiles, or chemical or biological weapons."
iTunes End User Licence Agreement
Tim Jones
on Feb 10, 2014 at 4:27:06 pm
Your HBA doesn't support I/O blocks of 512K. While raw LTFS allows you to set other block sizes when you format a tape, the HP StoreOpen app does not. Additionally, using other blocks sizes can make your LTFS volumes incompatible with other platforms' / vendors' LTFS configurations.
The only solution is to change your SAS HBA for a card that supports larger block sizes - we recommend ATTO Technology R680 (RAID) and H680 (non-RAID) cards even for Windows and Linux.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
