LTO/LTFS Solution For OS X
COW Forums : Archiving and Back-Up
Kevin Patrick
on Jan 3, 2014 at 7:48:33 pm
I'm in the process of upgrading my old gas-fired Mac Pro 3,1 to the Mac Pro iTube, also adding a lot more storage with a Pegasus2 array.
I'm looking for advice for LTO back up solutions for this setup.
Which LTO drive?
Which LTO SW?
Which TB2 to LTO interface? (SAS I assume)
I'm not even new to LTO, so I don't even know where to start, let alone finish.
Thanks.
Tim Jones
Re: LTO/LTFS Solution For OS X
on Jan 3, 2014 at 9:25:13 pm
Warning - vendor input below :) -
If you are hard-set on LTFS, any vendor's solution will work (as well as LTFS works). I prefer the HP solutions because HP at least acknowledges that Mac computers exist and the real people use them. With the other guys, you are kind of on your own in OS X-land.
If, however, you are just looking for LTO support for your OS X world that happens to include LTFS support in addition to a more traditional and reliable backup / archival solution, you might take a look at our ArGest solutions.
ArGestĀ® Desktop LTO Solutions for OS X
LTO drive, media, cleaning cart, cables, BRU PE or BRU Server software, warranty and support that KNOWS Mac OS X and the NLE world and a number of Thunderbolt connectivity options from a single point of contact.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.productionbackup.com
BRU ... because it's the RESTORE that matters!
Ajit Nair
on Nov 16, 2014 at 9:41:14 am
Hi Kevin,
Just to keep you informed, you can also look into Storage DNA Evolution which is a Mac based LTO LTFS based archiving software.
I don't know what is your archive size .. if you want to use a library the please look into Spectra Logic T50e an entry model with spectra media on it using spectra's own media lets you utilize MLM its a tool basically keeps a track record of the tapes like health checkup,mount& unmount counts,format counts etc.
http://www.spectralogic.com/index.cfm?fuseaction=products.displayContent&Ca...
I would like to highlight some of the key features of Storage DNA.
It uses open LTFS to store the data without using any proprietary wrapper.
SDNA keeps you metadata also on open XML so you have full access to both your data and metadata that means tomorrow if you don't have SDNA still you will able to retrieve your contents back just by using LTFS. SDNA is also integrated with a MAM engine which can do custom meta tagging, watch previews, add clip notes again these are searchable.
for more information you can visit SDNA website.
http://www.storagedna.com
