Commotion 3.11 display problem
COW Forums : Commotion
Paul Nixon
on Nov 30, 2005 at 6:33:15 pm
Hi folks,
I changed my system from an Athlon 2500+ to an A64x2 3800+ and from a Radeon 9800Pro AGP to a Radeon X550 PCIe, and I'm having a real problem with flicker on the Commotion tool boxes/buttons. OS is Win2k. I had some mild flicker in the past with the 9800Pro but nothing like this. Display is set for 1280x1024x32bpp@75Hz. It's also very unstable now.
If you need more info, let me know.
Recommendations?
Paul Nixon
Matt Silverman
Re: Commotion 3.11 display problem
on Nov 30, 2005 at 8:18:00 pm
Since we're a mac shop, the only fix I ever give for Windows is the same... try going to your QT control panel and switch it to "GDI Safe Mode". Seems to fix most issues on Windows.
Paul Nixon
on Nov 30, 2005 at 10:28:52 pm
I did as you suggested and it is rock solid now. Many, many thanks! Do you know if this has anything to do with, as I recall, some sort of incompatibility with >QT5?
Paul Nixon
Matt Silverman
on Nov 30, 2005 at 10:40:40 pm
It's just a simple fact that Puffin never had time to iron all of the bugs out of the Windows version, and Pinnacle never bothered updating it.
Paul Nixon
on Nov 30, 2005 at 11:54:02 pm
I think Microsoft is in the same boat. ;-)
I can't complain - I use what I have available.
Thanks again...
