Preview DV & Commotion
COW Forums : Commotion
jburford
on Oct 25, 2005 at 9:31:37 am
I have Commotion 4.1 Pro installed on a new System that also includes a Firewire (DV) card internally. But regardsless that the DV Output is physically there, from within Commotion, the option Preview DV is grayed out.
Is there some setting needing to be changed first for this to work, or does it simply not work?
Regards,
Jeff
cowcowcow
Matt Silverman
Re: Preview DV & Commotion
on Oct 25, 2005 at 5:28:19 pm
I assume that the Firewire card in your computer does not support the QuickTime Video Output Component (QTVOUT).
jburford
on Oct 26, 2005 at 9:25:11 am
Hi Matt,
hmmnn, good question, I have never heard of this QuickTime Video Output Component (QTVOUT). Is this standard on all/most Firewire cards? I guess I need to figure out which card is in the System and get with the manufacturer to find this out. .
jburford
on Oct 26, 2005 at 9:56:35 am
In looking at the website of the manufacturer, there is no mention of QuickTime Video Output Component (QTVOUT). I sent them off an email asking them for further information.
I do have another Firewire card at home (Pinnacle from the LE 5.5 Set), but not certain if that supports it either. Guess I might have to go buy another card.
Thanks again.
Matt Silverman
on Oct 26, 2005 at 4:29:13 pm
I am guessing that most windows based firewire cards do not support it. Some write their own output drivers (ie. Matrox) for After Effects which "might" work in Commotion.
jburford
on Oct 27, 2005 at 9:23:54 am
I received the following from the manufacturer of the Card.
Dear Mr./Mrs./Ms. ,
since the card only delivers a kinf of lower layer for data transformatoin,
such upper protcols like quicktime transport protocols should be integrated
in the software, not the hardware.
Please can you refer?
Kind regards,
Mario Seng
QTEC Customer Care
Matt Silverman
on Oct 27, 2005 at 5:21:12 pm
Programs like Commotion, After Effects, Combustion, Shake, ColorTheory ;-) etc. use the QT VOUT to send frames to an output card. The reason why they use QTVOUT is because they only have to write it once for their software and do not need to write specific code for each hardware vendor. It works the other way as well... the hardware vendors only have to write code for QTVOUT, and then it should work with any software supporting VOUT. Pinnacle does not waste any time on Commotion, much less write specific drivers for each new hardware card on the market. Instead they rely on the QTVOUT code to automatically work with hardware supporting QTVOUT.
However... now that I am thinking about it more, I think that maybe QTVOUT is a mac-only protocol, so maybe Commotion only supported this on a Mac. And this explains why After Effects on Windows needs a lot of custom plug-ins from the manufacturers to get output to work. You can learn more at:
http://developer.apple.com/quicktime/qttutorial/videoout.html
jburford
on Oct 27, 2005 at 9:24:56 am
So my question is anyone using this feature? If so, could they please provide the information of their card and setup. . .
Jeff
Matt Silverman
on Oct 27, 2005 at 5:21:40 pm
I use it on the Mac with Decklink HDPro.
