Different Frame Rates 60, 30, 24 in the same sequence.
COW Forums : Canon DSLR Cameras
Alex Hodges
on Dec 9, 2011 at 7:16:40 pm
Hello all, I've heard the golden rule is to put lower fps footage into the higher frame rate sequence, as opposed to the other way around.
I am working with shots in 23.98 fps, 59.94 fps, and 29.97 fps
Put them in the mpeg streamclip for the same frame size at 1280x720,
compressed with Apple ProRes 422, with my Pixel Aspect is Square.
Sequence settings
Frame Size: 1280 x 720 HDTV 720p (16:9)
Aspect Ratio: Square
Field Dominance: None
Editing Timebase is 29.97
Compressor: Apple ProRes 422
Quality: 100%
My Video Processing is on: Render 10-bit material in high precision YUV
Not sure if that's right. I want to achieve the fluid look of the 60, maybe put it into twixtor, and keep the look of the 24 and or 30 shots....
-Alex
