Canon Flicker when shooting TV screens
COW Forums : Canon DSLR Cameras
John Sherman
on Nov 18, 2011 at 2:32:34 pm
How can you eliminate flicker on tv and computer monitors when shooting with a Canon 60d at 24p?
Please help.
Neil Patience
Re: Canon Flicker when shooting TV screens
on Nov 18, 2011 at 7:01:14 pm
This is actually quite hard to eliminate as you are seeing a beating effect between the different rates of the monitor and camera.
A TV will also likely be different to a computer monitor.
The only way to do this is to use a shutter that matches the screen rate.
Usually you would set the shutter to be twice the frame rate (50 @ 24) but when shooting TVs etc experiement with the shutter to try to eliminate the flicker.
best wishes
Neil
http://www.patience.tv
