White dot only seen on Movies - EOS5Dii
COW Forums : Canon DSLR Cameras
Efe Ersoy
on Aug 2, 2011 at 9:26:38 am
Hi all
Recently my EOS5Dii started to add a single tiny white dot on movies. On photos there in none, even I take the smallest jpgs. Obviously it is not a dust.
Any ideas what is causing this?
Regards
Efe Ersoy
Peter Burger
Re: White dot only seen on Movies - EOS5Dii
on Aug 2, 2011 at 11:55:31 am
Could be a dead pixel. Had that problem a couple of months ago with tmy T2i. Mapping dead pixels out is quite easy:
Switch off the camera, remove the lens, put the body cap on the camera and switch it on.
In the menu go to "sensor cleaning" --> "clean manually". After a few seconds switch the camera off. Now the pixel should be gone.
hth
"Tragedy is a close-up; comedy, a long shot." - Buster Keaton
Bob Dix
on Aug 4, 2011 at 11:11:12 pm
A good tip , thanks Peter.
Freelance Imaging & Video
AUSTRALIA
Peter Burger
on Aug 5, 2011 at 8:01:28 am
You're welcome!
Efe Ersoy
on Aug 5, 2011 at 11:24:47 am
I thought manual clean means brushing the sensor. It really worked. Thanks a lot!
Peter Burger
on Aug 5, 2011 at 12:14:52 pm
Happy to read it worked!
This feature is indeed the only way to manually clean the sensor, since the mirror snaps back and you have access to it. The "mapping-out-dead-pixels"-feature is a "by-product" ;)
edmond ranson
on Dec 10, 2011 at 6:18:46 pm
thank you Peter
