Is there a way to get different aspect ratios on my DSLR?
COW Forums : Canon DSLR Cameras
ryan elder
on Dec 28, 2018 at 11:32:23 pm
When it comes to Canon DSLRS do they have softwares or apps that you can put on the camera card to shoot in wider aspect ratio options that are more wide than 16:9?
Blaise Douros
Re: Is there a way to get different aspect ratios on my DSLR?
on Dec 28, 2018 at 11:50:12 pm
No. It's a physical limitation of the sensor--there are no more pixels there to shoot wider. Even 16x9 is just a crop of the actual 3:2 sensor size--so you could always just crop it more in post, it would have the same effect.
You can always screw around with anamorphic lens adapters.
ryan elder
on Dec 29, 2018 at 1:20:01 am
Yeah that's what I mean is can I crop it in camera.
The problem with doing it in post, is that I still have to frame it in the correct aspect ratio while shooting. If I save it for post, then it is not correctly framed. Is there anyway I can get the aspect ratio in the camera before shooting in order to be able to frame it correctly?
Dave LaRonde
on Dec 29, 2018 at 2:44:08 am
My solution: two strips of tape: one at the top of the view screen, the other at the bottom, creating a viewable area in the proper aspect ratio. Pretty simple. Low tech. And it works.
Dave LaRonde
Promotion Producer
ryan elder
on Dec 29, 2018 at 7:11:30 am
Okay thanks, but I tried this before, and the problem with tape is, that it covers up the camera's information, such as ISO, aperture, shutter speed, etc.
I mean there is clear tape, but then I wouldn't see it when trying to shoot faster action scenes though, and it would be difficult to frame. So is there anyway to get black bars on the top and bottom of the monitor screen, and still be able to see the information?
Dave LaRonde
on Dec 29, 2018 at 5:23:46 pm
Build a matte box? Dry-erase markers at top & bottom? Your options are limited....
Dave LaRonde
Promotion Producer
ryan elder
on Dec 29, 2018 at 6:58:59 pm
Okay thanks. How would a matt box solve it? Are you saying that I should have the matt box fold over the lens to create the aspect ratio borders? Would that cut down on light entering the lens though if it's folded over that much?
I can see about that though.
Warren Eig
on Dec 30, 2018 at 6:03:50 pm
He's talking about a hard edge matte box. It crops the sensor as you shoot.
https://www.brighttangerine.com/store/hard-mattes/
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
Vimeo: https://vimeo.com/babyboompictures
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Warren Eig
on Dec 29, 2018 at 6:16:50 pm
Ryan,
If you install the free MagicLantern software on your camera, if you camera model supports it, you can crop in camera and even do 2:39 cinemascope. They are working on a version that supports shooting 4K on certain Canon DSLRs as well.
I've used ML for years to shoot CinemaDNG RAW in different aspect ratios. There are even frame guides as well as the ability to add your own.
Warren Eig
O 310-470-0905
ryan elder
on Jan 3, 2019 at 6:33:51 pm
Okay thanks. I was told that they didn't make a magic lantern yet for the latest Canon camera I was going to get. But maybe they will soon.
Sebastian Leitner
on Feb 4, 2019 at 10:25:20 am
no, magic lantern is dead on newer canon cameras – they changed firmware and simply blocked out any hacks.
but ML is enabling so much stuff on older models that make them a lot more interesting and valuable.
if you can, get a 5D mk3 and enjoy the wonders of ML! and the 4K crop build is already out but you need to download the "experimental" versions
ryan elder
on Feb 4, 2019 at 2:18:21 pm
Okay thanks. When you say 4k crop build, are you saying that magic lantern can add 4K to an HD camera?
Sebastian Leitner
on Feb 4, 2019 at 3:04:35 pm
only the 5Dmk3 can – in theory – record 4K in 1:1 sensor read-out (4x crop) via ML in RAW 14bit. depending on the speed of the memory card. more realistic is up to 3.5K though and not continuously but in bursts (for now). but 2.5K run smoothly in crop mode and obviously FHD without the crop. but the 4K crop experimental build enables you to use this particular crop also for normal h264 recordings giving you FHD but nearly 4 times the focal length
ryan elder
on Feb 4, 2019 at 3:08:25 pm
Okay thanks, but how would you have 4 times the focal length? Are you saying to shoot as close as you can to 4k and then zoom it in post?
Sebastian Leitner
on Feb 4, 2019 at 3:46:17 pm
you can familiarise yourself how ML RAW 1:1 crop works in the ML forums and descriptions.
very short story: as the name suggests it's a 1:1 sensor read-out as opposed to normal canon video mode where the full sensor is used but scaled down to FHD. 1:1 means pixel-perfect, so it's a strong center crop and only parts of the sensor are used – the only way to record in such high quality because processing power and memory speed are very limited.
ryan elder
on Feb 4, 2019 at 4:09:31 pm
Oh okay. So you record in 4K, then it's not using the whole frame, you are saying? But how is this possible on an HD sensor, since an HD sensor does not actually have enough pixels on it, to get up to 4K or even around 3K?
Sebastian Leitner
on Feb 4, 2019 at 4:36:14 pm
you do not understand how DSLRs work – they are for photography, so obviously they have a much higher resolution and pixel count on the sensor. if you take a look at the specs of, say the 5Dmk3, you see it's around 5K. so, if you read out the full sensor you need to scale down to make recording work. magic lantern circumvents that and delivers direct read-outs but at the cost of sensor surface. magic lantern even adds HDR and dual-iso which brings the full dynamic range (14 stops – the most popular digital cinema cameras by ARRI only provide 13), to your footage, but it needs post-processing and does not work out of the box. this is another matter though.
in ML you can choose different aspects in RAW mode, without crop only 1920x1080 is the maximum though. you can shoot in scope or flat, which would refer to 1920x803 and 1920x1038 respective. for anything beyoond you would need to use crop and an extremely fast CF (not SD)
ryan elder
on Feb 4, 2019 at 6:57:10 pm
Oh okay. So you are saying that with MF, I can use a full frame and shoot in a 1:1 aspect ratio if I wish though?
