Teleconverters and B4 Lenses
COW Forums : Canon DSLR Cameras
Sejin Kim
on Feb 4, 2017 at 8:22:39 pm
NOTE: I'm not sure if this is the right categorization; if it can go in a better one, please tell me.
I recently acquired a Canon B4 broadcast lens that I would like to use with EF. I removed the servo unit for full manual control. I was originally going to use just a converter from B4 to EF, but came across some discussion about the vignetting, even on APS-C sized sensors. Flange distance isn't TOO big of a problem since the lens has an adjustable flange distance. If anyone has experience with this conversion (or lens conversion in general), what can I do? What factor of teleconverter would you suggest I use (1.4x or 2x)?
If this information is pertinent: Canon BCTV Zoom Lens - Model YJ17X9.5B 9.5-162mm 1:1.8
Warren Eig
Re: Teleconverters and B4 Lenses
on Feb 5, 2017 at 6:31:18 pm
I've never done this or seen it done, but B4 lenses are more geared to ⅔" chip cameras. A much smaller sensor than an APS-C sized sensor, so yes you are going to get vignetting. I'd imagine it will be multiplied with a teleconverter.
Warren Eig
O 310-470-0905
email: info@babyboompictures.com
website: http://www.BabyBoomPictures.com
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Blaise Douros
on Feb 7, 2017 at 8:03:40 pm
This is not possible, period. The sensor on a 2/3" camera is tiny compared to APS-C, and the image circle of the lens will not come anywhere close to covering it. You'll be looking down a tunnel. It's not worth wasting your time and money; sell the lens and buy something useful.
Here, follow this link to see the size difference:
http://4.bp.blogspot.com/-ilHAFynRQXM/T8G_r6ZJliI/AAAAAAAAAU4/BXYbv7klZaI/s...
