Using proxies from DNG
COW Forums : Canon DSLR Cameras
alex gat
on Jun 2, 2015 at 12:24:15 pm
Hello all,
I jave just finished a raw production and I am now preparing the editing process.
I have converted the raw files form ML into DNG files for Davinci. I will do a quick look and will export them into prores to edit in Premiere.
My question : I will edit with prores files. When done, I will go back to Davinci for color grading. When that moment comes, will I be able to swap my prores files with the DNG ones ? Is that the whole principle of proxies ? I think it is but I wanted to be sure.
I want my movie to be a black and white one. Obviously I have shoot in color and will do some channel mixing to go from color to B&W when the time comes. But I want to edit in B&W, so I wanted to do a simple desaturation when converting my DNG to prores. That is why I'd like to be sure that I will be able to swap the prores files with the DNG ones when my edit is completed.
Thanks for your replies.
Alex
alex gat
Re: Using proxies from DNG
on Jun 7, 2015 at 12:26:33 pm
Hello,
I did not receive an answer to my post, so I send it at the top again.
My question is :
Is the conversion from DNG to prores only to edit ? Will I be able to get back to the DNG files when color grading ? Is such case I don't need to worry too much if I did not get the white balance right or any other adjustement when I created my prores proxies.
thanks.
Alex
Warren Eig
on Jun 7, 2015 at 6:10:04 pm
Yes, you should be able to go back to the original DNG. It is a bit like working with Red footage. You edit the progress then relink to the original files.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
