Why is Canon 5D Mark 111 HDMI output 1080i 59.97 ?
COW Forums : Canon DSLR Cameras
Mark Shepherd
on Aug 21, 2014 at 2:52:03 pm
Interlaced output, why on the Mark3 ? I am doing some tests with the Canon 5D Mark3 in the studio, recording the HDMI output to the AJA IO HD, trying to get PRORES HQ at 1920x1080 24p .. To my surprise, the "mirrored" output of the Mark 111 , even though the camera is recording at 1920x1080 29p is outputting via the HDMI cable , at 1080i at 59.97. Does anyone know why the camera is NOT outputting 24p ?
Warren Eig
Re: Why is Canon 5D Mark 111 HDMI output 1080i 59.97 ?
on Aug 21, 2014 at 4:58:43 pm
You wrote 29p did you mean 24p?
Mine outputs to 1920x1080 23.976fps as it should. That's the whole point. How are you testing and confirming it is 59.97?
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Ryan Holmes
on Aug 21, 2014 at 8:19:22 pm
Mark you should double check your settings in camera and on the AJA box. On my 5D if I set it to 1080p24 (23.976) it sends that out the HDMI port. I'm verifying that via a SoundDevices PIX240 external recorder.
It sounds like one of your devices in the chain isn't setup correctly or is incorrectly interpreting the signal.
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Mark Shepherd
on Aug 22, 2014 at 5:17:40 pm
Thanks, I have checked everything possible.
Ryan Holmes
on Aug 22, 2014 at 6:16:33 pm
[Mark Shepherd] "Thanks, I have checked everything possible."
It's your IO HD. It can't take in 1080p24 signal. It can only output 1080p24. Page 15 of the manual states:
[AJA IO HD Manual] Formats supported (video only):
525i, 625i, 720p 50/59.94/60, and 1080i 50/59.94/60 are supported on input and output.
1080p23.98, 1080p24, 1080p25, 1080p29.97, and 1080p30 are supported for
output only."
http://www.aja.com/assets/support/files/1080/en/AJA_IoHD_manual_v9.0.1.pdf
You'll need to update to a more modern IO device for capture. The IO HD was made back in 2007 as one of the first ProRes over Firewire IO devices certified by Apple. 2007 the 1080p24 format was not nearly as prevalent as it is today.
Ryan Holmes
@CutColorPost
Mark Shepherd
on Aug 25, 2014 at 9:38:33 pm
Thanks Ryan for the info. What is strange is that is detects the signal out of the Mark 3 as 1080i 59.57, even when it is set to 108024p. It is a false detection.
Ryan Holmes
on Aug 25, 2014 at 9:45:54 pm
[Mark Shepherd] "What is strange is that is detects the signal out of the Mark 3 as 1080i 59.57, even when it is set to 108024p. It is a false detection."
I'm not positive that it's a false detection. Canon's cinema series (C100/300) actually sends a 1080i59.97 signal out of it's cameras when recording 1080p23.98, with a flag in the stream to denote a 3:2 pulldown needs to be applied. So devices like SoundDevices PIX, Atomos Blade, Convergent-Design Odyssey will detect the flag and pull down a clean 1080p23.98 image.
I'm wondering if the DSLR does this as well since your IO HD is able to detect a signal. But on my other recorders my 5D3 shows 1080p23.98 as the input signal with no pulldown. DSLR's aren't made for video....that's for sure! :-)
The benefit though, is that if your IO HD can see the signal coming from your 5D3 then it can output to 1080p23.98. So you can still get to your final format without having to upgrade I/O devices as a suggested earlier.
Ryan Holmes
@CutColorPost
Mark Shepherd
on Aug 26, 2014 at 3:56:30 pm
Ryan:
Thanks for the info. U Da Man... Will try to output the 1080i signal to 1080 23.97p as you suggested.
