Headhone gain for 5D III?
COW Forums : Canon DSLR Cameras
Nick Griffin
on Jun 12, 2014 at 4:54:35 pm
Is there a control for getting more volume to the headphone output. (And WOW, is the manual that comes with this camera inadequate. I mean seriously incomplete and obtuse.)
Ryan Holmes
Re: Headhone gain for 5D III?
on Jun 13, 2014 at 1:47:07 am
DSLR's = use second source audio. The in-camera audio on DSLR's should really only be used as scratch audio, in my opinion.
Your question about adjusting headphone volume is answered in the Canon manual, page 235.
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Nick Griffin
on Jun 13, 2014 at 3:18:29 pm
[Ryan Holmes] "answered in the Canon manual, page 235"
Thanks, Ryan. Actually page 237.
[Ryan Holmes] "DSLR's = use second source audio. The in-camera audio on DSLR's should really only be used as scratch audio"
I fully agree and certainly would never use the camera's mic for anything but reference. The add-on mini shotguns are only minimally better and certainly not acceptable for professional work.
What I have been experimenting with are external XLR mixers which feed the camera's mic input. Conclusions so far is that the JuicedLink "ultra portable mixer" (at least the one I was using) introduces waaaay to high of a noise floor to be ever considered for serious work. On the other hand the Sound Devices Pre-Mix D outputting at line level, and with the camera's input level cranked down to one step above off, sounds fantastic. Problem is whether or not it sounds $900 fantastic so I'll probably keep looking.
We primarily bought the 5D mk III to do static interviews on location, so I really want to stick with a single system approach if at all possible.
Special thanks to the Audio Cow's Ty Ford for allowing me to test and playback both of these options in his studio.
Warren Eig
on Jun 13, 2014 at 5:08:15 pm
As Ryan said, It's a double system camera. Think of it as a 'Film' camera. You have to record and control sound through a separate device.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Ty Ford
on Jun 13, 2014 at 6:17:02 pm
The TASCAM DR60D is also a great way to capture sound for the mk iii.
Even though it's a mixer and recorder, it's line output works much the way the Sound Devices Mix Pre D does and it's a lot less expensive. ($349) More here.
http://tyfordaudiovideo.blogspot.com/2013/10/tascam-dr-60d-four-track-digit...
Nick and I didn't have time to get into that, but I did the work previously with local DP Rick Diamond and found the DR60D and mk iii made acceptable 16 bit files on the camera. No double record required. The DR60 D is a bit of a battery hog. You could choose to use the DR60 D to double record or to feed the mk iii.
Regards,
Ty Ford
Want better production audio?: Ty Ford's Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford's Blog
Roy Plisko
on Oct 3, 2016 at 8:49:20 pm
So I googled "headphone gain on Mark iii" and came to this post where someone actually took the time to look it up in the manual. . . just to tell everyone in a public forum the page number to go look themselves. There's some lost time I will never get back.
Ira Herman
on Mar 21, 2017 at 9:04:06 pm
I had to reply here because the Internet needs more info than checking a page in the manual. Fortunately for me, I have the manual so that was actually very helpful. Here's what to do:
To turn the volume up or down in video mode:
hit the Q button
hold the RATE button and press up or down on the multi directional controller.
This turns the volume up or down -- there is no visual display of headphone level, you can hear the difference though as you do it.
Hope that helps future people who find this on a google search!
