converting a 60fps 1280x720 to a slowmo 23.98fps clip
COW Forums : Canon DSLR Cameras
marc horowitz
on Mar 17, 2011 at 1:42:07 am
I'm having a hard time finding info on how to convert a 7d 60fps 1280x720 to a slowmo 23.98fps clip and then importing into final cut. Do I use cinema tools to change the frame rate? What are the steps in that case? Or can I do this in FCP? Do i start with the original h.264 file or use the converted prores422? just not sure what is best or where to start. Thanks very much.
Rafael Amador
Re: converting a 60fps 1280x720 to a slowmo 23.98fps clip
on Mar 17, 2011 at 8:53:19 am
Hi Marc,
You need to Conform the file in CinemaTools.
Is just a click. No rendering involved.
Duplicate your file before, because the operation has no way back.
rafael
http://www.nagavideo.com
