Noise and Grain
COW Forums : Canon DSLR Cameras
Kyle Blackwell
Noise and Grain
on Oct 10, 2013 at 12:36:08 pm
Hey Everyone,
i'm currently using the Canon EOS 5D Mark II, and trying to set up a shoot. I have been watching videos, reading up, and just generally trying to get the most out of the DSLR. I downloaded and installed the Cinestyle settings for the camera, did some still test shots and got the color grading down to how I like it. However, when I went to the set and did a few video test shots, I came back only to find out that no matter what F-stop or iso i am at, I am just getting an excessive amount of noise/grain from using Cinestyle. I tried doing a lens cap test with iso settings to confirm it was Cinestyle settings that was causing the noise/gran.
I was wondering if there is something I am doing wrong, or a way I can remove the grain in post w/o spending alot of plugins? I would love to use Cinestyle, but won't be able to if I can't solve the noise/gran issue as it makes my footage un usable at all combinations of f-stops and iso. Thanks in advance.
Kyle Blackwell
Re: Noise and Grain
on Oct 10, 2013 at 1:22:45 pm
forgot to add in; should I keep using Cinestyle, switch to standard, or something else? Thanks again.
Warren Eig
Re: Noise and Grain
on Oct 10, 2013 at 4:47:13 pm
How are you post processing the h.264? Are you? What are you editing in. My work flow is to use 5DtoRBG Batch. There is a free version from the Mac app store called 5DtoRGB as well. This is on a Mac. I process to ProRes422 and have not experienced any noise with the Cinestyle setting.
I only shoot at ISO 160, 3204, 640, or 1280.
Unfortunately, I don't know your work flow.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
Kyle Blackwell
Re: Noise and Grain
on Oct 10, 2013 at 4:55:04 pm
As far as ISO levels, I started out by stay to the same levels you are using, but the more tests I did, the more I noticed the noise was showing up no matter the level. I even went as far as making a chart of F-stops and ISO levels and just taking 5 sec clips at every combination of them. As far as work flow goes, I usually just import the footage into FCP (Log and Transfer), which it then converts it to pro res 422. However, The noise is bad enough that I can see it even on the DSLRs LCD screen, even at low levels of ISO / f-sop. I have also tried pulling the footage directly from the card and dropping it into After Effects.
Warren Eig
Re: Noise and Grain
on Oct 11, 2013 at 4:05:20 pm
Are you lighting? or just going with available lights. Not enough light will cause noise in the blacks Heat can also be an issue and of course it cold be a bad chip/sensor. Can you rent a 5D Mark II and do a side by side comparison? If the rental doesn't exhibit the problem, and yours does, it might be time for service.
Warren Eig
O 310-470-0905
Kyle Blackwell
Re: Noise and Grain
on Oct 11, 2013 at 4:09:27 pm
I am using lighting. I will have to see if the camera shop has a mark ii to rent, and will try that. Thanks!
