Canon Eos plug in
COW Forums : Canon DSLR Cameras
Suzin Daly
Canon Eos plug in
on Aug 13, 2013 at 3:14:03 pm
I am trying to bring in footage from Canon Rebel T4i. I downloaded the plug-in from Canon, link I was given Mark II, I downloaded from the Mark III. It looks to be the same. I was under the impression once the plug-in was down loaded and installed I would be able to log and transfer. However the log and transfer does not find the footage. What am I missing?
Warren Eig
Re: Canon Eos plug in
on Aug 13, 2013 at 4:32:41 pm
Try 5DtoRGB free from the App Store or the paid batch version which allows you to set up a render queue so you don't have to sit and do one at a time. Much better results and multi-processor aware so it is much faster.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
Suzin Daly
on Aug 13, 2013 at 5:54:10 pm
Warren,
Thank you for the information. When I checked I would have to upgrade to 10.7 or more. Right now on am on 10.6 For now I am using a work around with MPEG Stream. It works well enough.
Best
Sz
Ryan Holmes
on Aug 15, 2013 at 2:00:54 pm
Suzin - You have to keep the CF card structure intact when you transfer it over to your hard drive. So you can't just grab the .MOV files and expect FCP L&T to see them. You have to bring the whole card over with its various folders and files.
But again a program like MPEG Streamclip or 5DtoRGB will just grab the .MOV files and convert them to whatever you specify.
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost
Suzin Daly
on Aug 16, 2013 at 2:06:11 pm
Ryan,
Thank you again pointing out about the 'CF card structure intact' .
That I do understand and have kept it intact.
Knowing people who have used the Canon Plug in and having it worked made me a bit of a pit bull in wanting it to work for me too. It seems it is a problem for the t4i, and others have had to modify the .plist... I am not going there.
As you had suggested about other third party such as MPEG... that is what I am using. For now it works great and all I am doing is simple test shots etc. If in the future I get heavy into the Canon.... then I will research and look into other recommendations you have already mentioned.
On another note, I again thank you for your response and taking the time to give guidance. It is truly very much appreciated.
Best
Sz
Ryan Holmes
on Aug 16, 2013 at 2:15:53 pm
[Suzin Daly] "On another note, I again thank you for your response and taking the time to give guidance. It is truly very much appreciated. "
No problem. Glad to help.
You may look into getting out of the Canon consumer DSLR world - t3i, t4i, etc. If you move up into their "professional" bodies I don't think you'd have these problems....at least in my experience I haven't had them. I use a Canon 7D and 5D Mark III. But there's also the 6D (and maybe the 60/70D would work better). Just something to consider if you want to go further down this road....
Ryan Holmes
@CutColorPost
Suzin Daly
on Aug 16, 2013 at 5:42:31 pm
Ryan,
Once again I thank you for taking the time to offer further information. I would definitely take your recommendations into consideration if I decide to move up to a new DSLR.
Best
Suz
