Artificating when converting 5D to ProRes 4444
COW Forums : Canon DSLR Cameras
Danielle White
on Dec 13, 2012 at 7:30:23 pm
I have been using mpeg streamclip to convert 5D footage to Apple ProRes 4444 to be used in Final cut. I have interlacing turned off. I am selecting unscaled as the frame size. I have also tried several different codecs. Every time I convert, I am seeing artifacting in my reds. Has anyone else had this problem? Any ideas for fixes?
Sareesh Sudhakaran
Re: Artificating when converting 5D to ProRes 4444
on Dec 14, 2012 at 9:22:57 am
Export an uncompressed TIFF frame from your NLE, at the point where you think the effect is worst. Assuming you haven't blown the red channel during acquisition, it could be a quirk in the converter.
Or, it could be a monitor problem. Have you checked it on another monitor?
http://www.wolfcrow.com - Workflow information and support for filmmakers, photographers, audiographers and videographers.
