5D MKii won't output HDMI to Ikan monitor
COW Forums : Canon DSLR Cameras
Justin Crowell
on Dec 11, 2012 at 5:21:33 pm
Hi All,
All I get on my Ikan is a blue screen. I do have picture on the 5D, and I'm assuming that screen should turn off, correct? Can't seem to find info on this anywhere else. Is there a setting I need to switch?
Justin
Video editor, animator, composer, producer
JustinCrowell.com
Sam Red
Re: 5D MKii won't output HDMI to Ikan monitor
on Jan 7, 2013 at 10:41:26 pm
Hard to tell without specifics But here is my suggestion: Check that your HDMI wire is properly plugged in and or working properly or just get a new one as they tend to break internally.
hope that helps
-SAM
Justin Crowell
on Jan 17, 2013 at 8:30:33 pm
My apologies for not closing this thread...skilled workman that I am, I didn't try restarting the camera. That, eventually, did the trick!
JustinCrowell.com
Sam Red
on Jan 22, 2013 at 5:25:09 pm
Hi, It sounds to me like the HDMI you are using might be bad, I would try a new one.
Let me know if that helps.
SAM
