Problem with import footage from canon 650D to Final Cut 7.03
COW Forums : Canon DSLR Cameras
NIcholas Lawson
on Nov 18, 2012 at 1:09:59 pm
Hi i just bought a cannon 650d to do some editing in final cut pro,
but i cant seam to get the footage on to the log and tranfrer page---
do i need to down load a new plug in?
or use a programe like pavtube to convert the footage ?
any advise would be great as abit confused
thanks
Joe Gallant
Re: Problem with import footage from canon 650D to Final Cut 7.03
on Feb 10, 2013 at 4:18:38 pm
Download the newest update of the Canon final cut plugin, then change the 'cameras' plist file. It has to be the newest version otherwise won't work.
The plugin can be found here:
http://usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_5d_mark...
http://cl.ly/image/3V3x2j3X0r3O
Your plist file, once installed, can be found here:
/Library/Application Support/ProApps/MIO/RAD/Plugins/CanonE1.RADPlug/Contents/Resources
And it should read as follows:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>6D</key>
<array>
<string>Canon EOS 6D</string>
</array>
<key>1D C</key>
<array>
<string>Canon EOS-1D C</string>
</array>
<key>60D</key>
<array>
<string>Canon EOS 60D</string>
</array>
<key>1D</key>
<array>
<string>Canon EOS-1D Mark IV</string>
</array>
<key>5D</key>
<array>
<string>Canon EOS 5D Mark II</string>
</array>
<key>7D</key>
<array>
<string>Canon EOS 7D</string>
</array>
<key>1D X</key>
<array>
<string>Canon EOS-1D X</string>
</array>
<key>5DMarkIII</key>
<array>
<string>Canon EOS 5D Mark III</string>
</array>
<key>600D</key>
<array>
<string>Canon EOS 600D</string>
</array>
<key>T3i</key>
<array>
<string>Canon EOS REBEL T3i</string>
</array>
<key>650D</key>
<array>
<string>Canon EOS 650D</string>
</array>
<key>T4i</key>
<array>
<string>Canon EOS REBEL T4i</string>
</array>
</dict>
</plist>
Hope this helps
