Incredibly Shaky Pans with Tripod
COW Forums : Canon DSLR Cameras
Howard Neuthaler
on Oct 8, 2012 at 2:14:42 am
I just shot several pans with my Canon T2i (with Magic Lantern) on a tripod, and I cannot believe the amount of vibration/shake that is present in the video. The lens is a Canon 24-70mm f/2.8L. I'm shooting at 24p @ 1/47. The video is at
I've used this tripod before (a Ravelli), and I've never had this issue. Any ideas what I'm doing wrong? Thanks in advance.
Bob Dix
Re: Incredibly Shaky Pans with Tripod
on Oct 9, 2012 at 10:29:47 pm
Have you turned of the Image Stabilizer ?
Freelance Imaging & Video
AUSTRALIA
Howard Neuthaler
on Oct 9, 2012 at 10:30:47 pm
Thanks for your reply. My lens does not have IS.
Bob Dix
on Oct 9, 2012 at 10:38:04 pm
Ah, well try using the image stabilizer in Premiere Pro CS5.5.2 or CS6 if all else fails.
Good luck !
AUSTRALIA
Howard Neuthaler
on Oct 10, 2012 at 2:19:10 am
Yikes, I don't use Premier.... Thanks anyway!
John Smith
on Oct 11, 2012 at 3:38:45 pm
If it's the one with the pistol grip then it very well could be from hand shakes, or even the head it self. Ideally you'd want a fluid head and a panning handle so the vibrations would be minimal and the longer lever would give you smooth motion. Is this is the pistol grip model, try fashioning a handle, probably easiest with a metal tube
Howard Neuthaler
on Oct 11, 2012 at 6:55:48 pm
Thanks for your reply. The tripod has a fluid head and pan handle. Maybe the shakiness is just a product of the speed of the motion and the focal distance....
