5d mk2 709 color space flag
COW Forums : Canon DSLR Cameras
Stefan Bergfors
on May 31, 2012 at 10:15:47 am
Is it possible to change the color space flag to RGB without transcoding or converting?
Correct me if I'm wrong. 5d is recording in RGB color space, but when I check the files with MediaInfo it says
Color Space: YUV
Color Primaries: BT.709-5
And so on.
And why is the Matrix coefficients 601? Shouldn't it be 709 as well?
-Stefan
Confused, but not yet dazed
Everest Mokaeff
Re: 5d mk2 709 color space flag
on May 31, 2012 at 4:35:21 pm
Since Mark III Canon 5D records in bt.709 color space. Mark II uses bt.601. You can change it to 709 while transcoding at your peril - from my own experience I can testify that consequences are dramatic color shift - in cases of mixed sources of light 5DtoRGB, for instance, rendered it almost unusable.
Production and Postproduction in Moscow
http://www.mokaeff.com
