Canon HDSLR Footage and Alpha Layers
COW Forums : Canon DSLR Cameras
Teresa Seito
on Apr 12, 2012 at 5:54:16 pm
Hi, I have a question whose answer I might have figured out, but I'm not sure.
I am importing Canon HDSLR footage into AE, and I notice that AE gives it an opaque (white) Alpha layer in the Alpha channel.
Is there a way to add an Alpha Channel that represents opaque and transparent regions to footage without resorting to masks?
Just curious.
Thanks for your help.
Peter Burger
Re: Canon HDSLR Footage and Alpha Layers
on Apr 13, 2012 at 9:26:11 am
Not quite sure what you mean. Maybe I misunderstood.
When importing any footage that has no alpha information natively, AE "adds" opaque alpha-information.
There are several ways to add your own alpha information to the footage. Masks are just one of them. To then bake the alpha information into the footage, you'll have to render it out to a format that supports alpha channels - like Quicktime (codecs could be Animation, PNG, ...). In the render settings you'd have to tell AE to put the alpha information in (RGB + alpha).
Was that your question? :)
"Tragedy is a close-up; comedy, a long shot." - Buster Keaton
Me on Twitter (english/german)
http://twitter.com/FastFoodVideo
My german blog
http://fastfoodvideo.de
Teresa Seito
on Apr 13, 2012 at 11:48:26 am
Yes, thank you. I knew that AE adds an opaque alpha channel in. I was curious if there was some magic switch that would add a pre-multiplied layer with a range of transparency (from opaque to completely transparent)to footage that didn't already have an alpha layer. I assumed I could mask it or render it, but I was just curious if there was some magic switch that took the luma information from the color channels and then converted that info into an appropriate grayscale transparency that could rest in the alpha channel, and then be used for other purposes. Thank you very much for your advice! It confirms what I suspected. And thank you for the Cineform Neoscene advice for H 264 transcoding. It really helped my footage a lot!
Peter Burger
on Apr 14, 2012 at 2:11:37 pm
Glad, I helped!
[Teresa Seito] " I was just curious if there was some magic switch that took the luma information from the color channels and then converted that info into an appropriate grayscale transparency that could rest in the alpha channel, and then be used for other purposes"
There are a couple of ways to do just that. Simplest way to use the luminance information as an alpha channel, is to apply one of the channel effects (don't know the english name, must be something like "change channels"... something like that...)
You can simply choose the luminance information as an alpha channel.
Another way is to duplicate the layer, add a b/w effect (tint, b/w, hue/saturation, ...) to the duplicate and use that layer as an obscure matte (inverted luma matte) for the original layer. IMHO the better way, because you can tweak the matte to your liking with levels, curves or whatever...
I'm sure there are still about a hundred other ways to achieve the same (or better?) results.
All the best!
My german blog
