Glidecam and 7D - jitter/blinking issue
COW Forums : Canon DSLR Cameras
Oleg Solod
on Feb 14, 2012 at 2:20:01 am
Hi
Below is a link to a video, for some reason I am getting this jitter, almost like blinking with-in the frames while flying the 7D with 16-35mm lens. It doesn’t happen all the time but it does occur quite a bit. Seems like if I try and record in 720p at 60 frames I don’t see anything at all but at 24fps its quite apparent at times.
My shutter would normally be set at double the frame rate, so for 24, I would set it at 50 and at 30 fps I would set the shutter to 60.
Any advice or thoughts ?
