Is the 24 - 70 lens 'worth it' on a cropped sensor?
COW Forums : Canon DSLR Cameras
Ken Eakins
on Feb 10, 2012 at 8:09:42 pm
Hi there,
Quickie for you nice chaps, and chapettes.
I'm looking into buying a new lens for my 550D for video, I already have a 50mm, and the kit lens, but I've been told the 24 -70 is a 'must have' also. I was told this by the owner of a 5D, and that has a full frame sensor. I know that I have to consider the crop factor on my 550 when looking at lenses, so does this make the 24 - 70 'not as worth it', as if I was buying it for a full-frame?
Thanks in advance.
Ken Eakins
Re: Is the 24 - 70 lens 'worth it' on a cropped sensor?
on Feb 11, 2012 at 8:58:52 pm
Bump
Michael Sacci
on Feb 13, 2012 at 2:00:24 am
there are no bumps on the cow, the post stay put.
The question is one only you can answer. Do that range work for you. On your camera it basically a 38-112 mm. If you need a real wide lens it may not work. There are no "Must have lens" there are "right lenses for the right" job lenses and lenses that give you a range that is useful for you.
