Cannot change default frame rate hvx 200
COW Forums : Field Production
Paul jilbert
on Oct 25, 2010 at 1:17:47 am
Okay folks
yes there are many helpful tips to change frame rate in HVX Panasonic 200 cam so I set camera menu to "Film Cam" in 720pn but cannot change the DEFAULT speed as there are no other options under the DEFAULT mode. I know I'm missing something simple here so any help would be great! thanks
paul jilbert
Chad Tingle
Re: Cannot change default frame rate hvx 200
on Oct 26, 2010 at 10:14:50 pm
[Paul jilbert] "set camera menu to "Film Cam" in 720pn but cannot change the DEFAULT speed as there are no other options under the DEFAULT mode"
I believe you can only shoot at 24 frames with the 720p n (native mode)
Chad Tingle
Producer/Editor
Paul jilbert
on Oct 26, 2010 at 10:39:54 pm
Actually I did find the correct forward button to change the fps speed to 48 thanks for help though!
paul jilbert
Ty Clancey
on Jan 13, 2011 at 1:01:17 am
Okay, wanna fill us in on how you did it?
